Price: $36.99
(as of Sep 15, 2024 09:00:17 UTC – Details)
INSEETECH 4 pin aviation video extension cable with corrugation tube cover, high quality and exquisite workmanship, can be widely used in RV, Truck, Tanker Truck , Semi-truck, Trailer, Horse Trailer, Bus, Motorhome, Farm Harvester Tractor, Caravans , Van, Long-distance Car for connecting backup camera system, surveillance CCTV system.
Does this video cable support our system?
This 4 pin aviation extension cable is universal,as long as your backup camera system has the same connector with the same plug dimensions and pin configuration, you can use it for connection!
Note: This cable is not suitable for dash cam.
4-pin female to 4 pin airline aviation male extension cable. Dimensions of ends of cable: 9mm(Female),15mm(Male)
4 Pin Video Extension Cable with Polypropylene (PP)
Waterproof
Our cable sheath is made of 100% high-quality polypropylene (PP) with good flame retardancy for cable protection.
In addition, this cable is for the reverse camera system that have waterproof connectors. It comes with a rubber O-ring on the screw fit connector. At the same time, it is fitted with a waterproof case. The combination of this two make the join waterproof.
Frame retardant Anti-abrasion Waterproof and oil-proof Anti-corrosion
Easy installation
Plug and play.
Various application
4 pin video cable with corrugation tube cover is widely used in RV, truck, tanker truck , semi-truck , trailer, horse trailer, bus, motorhome, farm harvester tractor, caravans , van, long-distance car for connecting backup camera system, surveillance CCTV system.
Strong compatibility
The video cable is compatible with various devices, such as vehicle rear view system, radar system, DVR system, CCTV system, etc.
Pure copper
High-quality pure copper conduction and lossless signal transmission ensure more stable operation. 100% shielding provides outstanding interference protection for better image transmission.
High tenacity
PP material with good flexibility is not easy to be deformed and provides long-lasting protection to the cable.
Package
INSEETECH provides you with high quality 4 Pin Video Extension Cable with Loom Tubing Cover.
4.6 out of 5 stars
62
4.6 out of 5 stars
62
4.6 out of 5 stars
62
$36.99$36.99 $19.99$19.99 $28.99$28.99
Recommended Use
Automobiles Automobiles Automobiles
Length Size
33FT/10M 10FT/3M 16FT/5M
Surface Material
Polypropylene (PP) Polypropylene (PP) Polypropylene (PP)
Operating Temp (degree F.)
-40 to 230 -40 to 230 -40 to 230
9mm(Female),15mm(Male) 9mm(Female),15mm(Male) 9mm(Female),15mm(Male)
Flame Retardant: Operating temp (degree F.): -40 to 230 | The 4 pin backup camera extension cable sheath is made of entirely high-quality polypropylene (PP) with good flame retardancy for cable protection, so as to ensure that your backup camera system is able to work at low and high temperature.
Quality: The backup camera extension cable is snowproof, windproof, waterproof and shockproof, suitable for outdoor application even under severe weather. Protected by anti-abrasion and anti-corrosion conduit, can be used in various applications such as automobiles, construction machines and agricultural equipment.
Excellent Signal Transmission: Our video cable uses copper cores with shield, to ensure the conductivity for video and audio.
Excellent Compatibility: Compatible with various HD and D1 products, such as rear view camera system, radar system, DVR system, CCTV security system, etc.
Various Application:4 pin aviation extension cable widely used in RV, Truck, Tanker Truck , Semi-truck, Trailer, Horse Trailer, Bus, Motorhome, Farm Harvester Tractor, Caravans , Van, Long-distance Car for connecting backup camera system, surveillance CCTV system.
4 pin video aviation cable backup camera extension cord car rear view system back up waterproof reverse monitor wire power 10ft 3m connector male to female rv trailer truck motorhome vehicle automotive bus van conduit loom tubing cover pp shockproof
Customer Service: Our team provides a comprehensive pre-sale and after-sale service system. Feel free to reach out via Amazon Message with any questions about this product. We will resolve them within 12 hours.
