Price: $14.50
(as of Aug 07, 2024 09:15:30 UTC – Details)
High-quality Nozzle
Made of high-quality ceramic material to resist the high temperature, more safer and durable. Easy to jet high-pressure blue flame, windproof torch is not affected by the weather.
Flame Regulator
With flame regulator easy to adjust the flame height from Low to High by hand according to your needs
Step 1
Go to a wide and ventilated place.Release gas before filling, make sure no gas in the lighter. Step 2
Turn the flame adjustment wheel to “-“. Step 3
Turn lighter upside down.Insert ordinary long nozzle butane canister. Step 4
Please wait at least 2 mins before using. 1 Step 1 Release gas 2 Step 2 Turn to “-” 3 Step 3 Use right canister 4 Step 4 Wait 2 mins
Value 4 packs: Value pack of 4 butane torches enough for daily use such as candle, creme brulee or other food cooking. Keep two, gift two!
Safety Lock: Not only prevents accidental ignition to make sure safe but it also can be locked to keep firing. (Reminder: If you need to throw in your bag, make sure the Safety Lock is ON.)
Visible Gas Tank: Easy to check & to refill with the butane fuel in time.
Adjustable Flame: Easy to adjust the flame by the button from Low to High according to your needs.
Support by Samniu: 1-year-warranty & 24-hour-stand-by service team is your strongest shield.
