Price:
(as of Aug 17, 2024 05:30:32 UTC – Details)
4 Packs Lighters
Safety Button
There are two buttons, a safety lock slider to power on the device and a tactile clickable power button to activate the current.
Wind & Splash Proof
The candle lighter will protect the electric pulse from being blown out by strong wind.
it is very suitable for outdoor barbecue camping etc.
Rotate 360 Degrees
The electric candle lighter can be bent and rotated 360 degrees,and the angle can be adjusted according to the requirements of use.
Type-C Charging
This arc lighter can be charged directly from the power source or using a power bank,computer,etc,candle lighter can be used more than 500 times.
【USB Charging】:The arc lighter is equipped with USB charging,type-c charging interface,arc lighter can be charged directly from the power source or using a power bank,computer,etc,candle lighter can be used more than 500 times in per charge.The electric candle lighter with LED power indicator light,it can remind you to charge in time.
【Package Includes】Product set:candle lighter*4,usb charging cable*4.If you have any problems during use,please feel free to contact us,we will solve the problem as soon as possible.
