3G 4G LTE USB Router, Vehicle Router via Standard USB Port, 150Mbps Portable Router for Tablets, Laptops, Cell Phones and Different Types of Devices
Price: $16.81 - $15.33
(as of Aug 23, 2024 02:00:22 UTC – Details)
Spec:
Item Type: 4G LTE USB Router
Material: ABS
Color: Black
USB: Standard USB Interface
Card Slot: Standard SIM Card Slot (without SIM Card)
4G Speed: 150Mbps Downlink
4G LTE FDD: B1/B3/B5
3G WCDMA UMTS: B1
: Support IEEE802.11b/g/n Band 2.4G
How to Use:
Just take out the product to use
PackageList:
1
1 x User Manual
Note:
1.Without SIM Card2.You need to disable the PIN codes of SIM card and modify the APN. please make sure the SIM card is activated, roaming service and virtual SIM card, IOT SIM card are not supported; in rural areas, the uncovered will be disconnected for a period of time, which is a normal sign.
3.Before purchasing, check the frequency band used by your local carrier to ensure that it is compatible with your local usage.
MULTIPURPOSE: 4G LTE USB router, powered by USB port, can be used as a router or plugged into your computer USB port and used as a USB modem, no CD driver required, can be used in your car via standard usb port or outdoors with powerbank via standard usb port.
4G NETWORK: modem supports both 3G and 4G networks, using a standard SIM card as long as you have a 3G 4G SIM card, you can connect to a 3G 4G network.
SCOPE OF APPLICATION: 4G router is made of ABS material, and suitable for tablets, laptops, cell phones and different types of devices that can connect to 4G router to access the Internet.
SUPPORT 10 USERS: 4G router supports up to 10 users to access network at the same time, USB power, easy to use, lightweight and portable.
150MBPS: Mobile router with up to 150Mbps connection speed, you will enjoy a powerful internet experience for surfing, chatting and entertainment.
