300W Portable Power Station 260Wh Outdoor Solar Generators Mobile Lithium Battery Pack 110V Outlet Solar Power Bank Camping Power Supply for Laptop with 60W Solar Panel
Price: $298.97 - $219.99
(as of Aug 19, 2024 13:15:33 UTC – Details)
Small Portable Generators for Home Use portable laptop charger battery pack for laptop
jackery portable power station portable power station for boats solar charger external batteryjackery portable power station portable power station for boats solar charger external battery
Laptop External Battery With AC Outlet Portable Power Station Laptop Camping Charger Power Bank Portable Power Station 260Wh Outdoor Solar Generators
solar panel for portable power stationsolar panel for portable power station
300W Portable Power Station Solar Generators C Type Power Bank for Laptop portable ac outlet power bank portable battery to charge laptop
Q: What devices can G300 power to?
A: Please kindly noted that it can only charge the devices that less than 300 Watts, please check out the operating power of your device before use.
11
solar panels portable 120v battery pack portable compact powerful portable charger solar panels portable 120v battery pack portable compact powerful portable charger
generator with solar panelgenerator with solar panel
ackery solar power station with solar panelsackery solar power station with solar panels Easy Carry & Store
Designed with a hidden handle for space saving and portable to carry, provides convenience for your outdoor activities like camping traveling fishing hunting etc.
Tip: For better battery maintenance, It is recommended to use and recharge the power banks at least once a month if it’s not in use frequently. It is appropriate to keep the battery power at 20%-90%.
300W Portable Battery Powered Station (SOLAR CHARGER SOLD SEPARATELY)
260Wh/70000mAh Capacity: Provide enough juice to charge your cell phones, laptops, tablets, fans, drones and other small devices anywhere anytime.
Multiple Charging Ports: It comes with 9 output ports to meet your most charging needs.
Get Power From the Sun: With a solar charger (SOLD SEPARATELY), it helps you take the most advantage of the unlimited power of sunlight, no matter where you are!
Input: Wall socket: 100-240V; DC: Car Port 12V, Solar Charger 12-25V power stations AC Output: 110V, 300W total sinkeu portable power station USB-C: 5V/2.4A, 9V/2A, 12V/1.5A, 9V/2A portable charger power banks USB-A Outputs(2): 5V2.4A (5V, 3.1A total) battery generator DC Output: DC1: 12V/8A, DC2: 24V/3A portable battery packs Wireless Chargers: 10W(MAX) 300W Portable Power Station Solar Generator
emergency battery backup portable charger power bank portable charger with ac outlet emergency battery backup portable charger power bank portable charger with ac outlet
portable power bank portable power bank
11
Wireless Fast Charging for Laptops
Equipped with a 10W wireless charging port, no more worry about forgetting to take the phone charging cables on the trip. ( Please make sure your phone is lines up correctly with the charging port.)
LED Light For Emergency
Comes with 3 brightness lighting modes designed for power outage, outdoor night lighting and seek help when in trouble. perfect for outdoor activities such as van life, camping, hiking, outdoor photography and fishing.
Package Contents
1 x Portable Battery Pack With AC Outlet
1 x 12V Car Port Charging Cable of Portable Charger
1 x AC Home Charger of Camping Battery
1 x User Manual of Portable Battery Camping
4.2 out of 5 stars
1,040
4.2 out of 5 stars
1,040
4.2 out of 5 stars
1,040
4.2 out of 5 stars
1,040
$199.98$199.98 $229.99$229.99 $109.99$109.99 $109.99$109.99
Capacity
260Wh(70000mAh, 3.7V) 110v battery pack 296Wh(80000mAh) 155Wh(42000mAh) 155Wh(42000mAh)
Input
Charging Port: DC 5.5 x 2.1mm, 19V/3.42A max portable laptop charger Charging Port: DC 7.9*0.9mm, 19V/4.74A max Charging Port: DC 5.5 x 2.1mm, 25V/2A Charging Port: DC 5.5 x 2.1mm, 25V/2A
AC Output
110V 60Hz, 300W 110V 60Hz, 600W 110V 60Hz, 200W 110V 60Hz, 200W
DC Output
DC 1: 12V/8A DC 2: 24V/3A DC: 12V/8A max DC: 9-12.6V, 10A max DC: 9-12.6V, 10A max
USB-A Output
5V/2.4A(5V/3.1A TOTAL) 5V/2.4A(QC3.0 18W max) 5V/3.1A max 5V/3.1A max
USB-C Output
5V/2.4A, 9V/2A, 12V/1.5A rechargeable power supply 18W (5V/3A, 9V/2A, 12V/1.5A) portable battery 5V/2.4A, 9V/2A camping power bank 5V/2.4A, 9V/2A battery pack for camping
Wireless charging
10W(MAX) Portable Charger – 10W(MAX) Portable Charger 10W(MAX) Portable Charger
Lifecycle
>1000 Times to 80% Capacity Remained portable power bank >1000 Times to 80% Capacity Remained portable power bank >1000 Times to 80% Capacity Remained portable power bank >1000 Times to 80% Capacity Remained portable power bank
【Power Up Your Outdoor Life with High Capacity】Built-in a 260Wh/70000mAh rechargeable lithium battery pack with 110V 2*AC Outlet(300W Total). No gasoline or fuel needed, no smell, no fumes and noiseless! Safe and convenient, ideal for both home use and outdoor trip. Just take it to your trip and enjoy your relaxing & wonderful outdoor life!
【Multiple Charging Outputs Provide More Options】 It is equipped with 2*AC outlet(110V 300W), 2* USB ports, 1*USB-C, 2*DC ports, 1*car port and 1*10W wireless charging port. Deliver stable and security power to most of your devices (less than 300W) like laptop, phone, camera, drone, light, CPAP machine etc. Ideal for outdoor activities(camping, RV trip, fishing, hunting, boating) and home emergency(power outage, hurricane)
【Various Ways to Recharge】It can be recharged by wall AC outlet, solar panel, car cigarette lighter port and gas generator. SinKeu SE series solar panels are available and support fast recharging for G300 portable power station with ac outlet while traveling or camping (solar panel BUY SEPARATELY ). Take this portable solar generator with you on-the-go and get power from the sun anywhere. No more worry about power shortage, keep your outdoors always pumped!
【Stable Voltage & Safe Power Supply】SinKeu G300 is built-in excellent Battery Management System (BMS), protect devices through temperature control, overvoltage protection, overcurrent protection and short circuit protection functions. Detects short circuits and overloads when performing incorrect operations. Also, the Pure Sine Wave AC inverter can better protect your sensitive devices, ensuring the safety of you and your devices, preserve battery life.
【Your Satisfied is Our Priority】SinKeu offers 1* 12 months warranty, 7*24 hrs prompt and friendly customer service. Please contact us if there any issue arise. Package Included: You will receive 1x Rechargeable Generator Portable 260Wh, 1x AC power adapter, 1x car charging cable, 1x User Manual
