Price: $33.07
(as of Aug 12, 2024 13:00:14 UTC – Details)
How to Use:
1. Long press the power button to turn on the phone after charging
2. Press each application prompt to use
3. Press and hold the power button to turn off the phone
Specification:
Item Type: 2G Seniors Cell Phone
Material: Zinc Alloy, PC
Model: A6
Screen Size: 2.4in
Card Slot: SIM Card Slot x2, Memory Card Slot x1
Memory: 32MB, 32MB
Whether to Support Memory Card Function: Yes, Maximum 32G (Not Included)
Interface: Headphone Jack with Charging Port
Camera (PX): 8W
Battery: 6800mAh Li Ion Battery (Ship with Inbuilt Battery
Bluetooth: 2.0
Frequency Band: GSM (850/900/1800/1900)
Network Type: 2G GSM
Interface: Micro USB, USB
Vibration: Support
Product Size: Approx. 131.7 x 61 x 15mm / 51.9 x 24.0 x 5.9in
Languages: English, Arabic, French, Indonesian, Portuguese, Russian, Spanish, Thai, Vietnamese, Italian, Russian, Hebrew, Filipino
Package List:
1 x 2G Seniors Cell Phone
1 x Charging Cable
1 x User Manual
Note:
Note: 2G GSM (850/900/1800/1900) is supported; please check with your Sim card carrier for 2G network support. The flip phone is fully unlocked, but the carrier needs to support the product. (AT and T, T mobile U.S. These 2 carriers are confirmed to not support 2G anymore) (2G networks are not available in the US, Mexico, and Canada)
2.4in High Definition Screen: 2.4inch high definition screen, clear keys and numbers, antifall, three proof structure design, alloy frame to enhance shock absorption and antidrop.
Support Functions: Phone supports audio, video player, FM radio, bluetooth, camera, e book, flashlight, video recorder, voice recorder, calendar, alarm clock, calculator and other functions. Supports up to 13 languages.
Dual SIM: Phone supports 2g GSM quad band 850,900,1800,1900 and dual SIM. But it doesn’t support 3G, 4G, etc.
SOS Key: If you’re in an emergency, you can use the SOS feature to get immediate help. There are also 9 groups of family numbers, and 9 emergency contacts can be set. You don’t need to dig through the address book, you can dial with one key.
Ultra Long Battery Life: The mobile phone is equipped with a 6800mAh large capacity rechargeable battery, which has a long standby time, and a one button flashlight with LED light, which has a wider and farther lighting range.
