Price: $219.99
(as of Sep 29, 2024 12:00:23 UTC – Details)
Features
Complete Set: This kit contains the complete range of accessories needed to convert your bike without you having to buy them separately. The matching kit will provide you with more consistent and stable performance.
Details
Upgrade Display: The display shows real-time speed, maximum speed, average speed, total mileage, single mileage, battery power display, assist gear/speed grading, cruise function, so that you can charge in time and intuitively keep track of its operating status.
Pedal Assist Sensor: The pedal assist sensor (PAS) can sense the pedal rhythm and adjust the motor speed accordingly. It allows you to ride an electric bicycle without throttle response, which helps on long trips and reduces wrist soreness.
Waterproof Controller Bag: The waterproof controller bag can safely store the controller and allow for riding on rainy days.
Application
It is suitable for assembling and converting the 28-inch, 29-inch, and 700C front wheel of a bicycle. It is compatible with universal disc brakes and V-shaped brakes.
Specifications
Material: Aluminum Alloy
Color: Black
Suspension Type: Front
Special Feature: Electric
Assembly Requirement: Yes
Brake Type: Power-off Brake Lever (Applicable to V Brake, Disc Brake)
Motor Type: Brushless Gearless Motor
Gear Adjustment: 5 Gears
Recommended Battery: 48V 13AH or Higher Capacity Battery(Not Included)
Output Voltage: 48V
Power: 1000W
Minimum Flat Fork Distance: 100mm/3.94in
Speed: 45-55km/h
Display Size: 6.8*9.6cm/2.67*3.77in
Packing Size: 65*65*22cm/25.59*25.59*8.66in
Suitable Wheel Diameter: 28-inch, 29-inch, 700C
Gross Weight: 11kg/24.25lbs
Net Weight: 10kg/22lbs
Loading Capacity: 120kg/264lbs
Package Included
1* Motor Wheel
1* Display
2* Brake Levers
1* Controller
1* Thumb Knob Handle
1* Controller Bag
1* Pedal Assist Sensor
1 * Motor Cord
1 * Winding Pipe
1* English Instruction Manual
All Accessories for Assembly
【STURDY AND DURABLE】:Aluminum alloy wheel frame is very durable and stable to ensure a long service life and strong load bearing capacity up to 264 lbs.
【HUMANIZED FEATURES】:5-speed adjustable according to different road conditions and personal needs. Meanwhile, while keeping the riding speed, long press the button key for 2-3 seconds will enter the cruise function, making the riding process easier!
【HIGH POWER MOTOR】:Adopting 1000w brushless gearless motor, the maximum speed can reach 45-55KM/H.Compared with brush motors, it allows smooth, fast acceleration and low noise operation without the need to replace brushes, which makes maintenance easier.
【SAFE AND RELIABLE】:The brake lever can cut off the power supply to the motor during emergency braking to stop the bike in time and ensure safe riding.
【DUAL MODE CONTROLLER】:The motor works under Hall effect and non-Hall effect. If the component fails, the controller will switch to non-Hall effect mode and the motor will continue to work.
