26″ Electric Bike Conversion Kit, 350W Front Wheel Motor E Bike Kit 36V Hub Motor Bicycle BLDC Controller with LCD Display Controller PAS Brake Lever for 26X1.95 Tire, 5 Speed Adjustable
Price: $159.00
(as of Sep 29, 2024 15:00:17 UTC – Details)
26 inch electric bike conversion kit 350w front wheel motor e bike kit 36v hub motor bicycle bldc 2626 inch electric bike conversion kit 350w front wheel motor e bike kit 36v hub motor bicycle bldc 26
Are you an avid cyclist? Do you usually find it difficult to climb hills on a bike? Do you want to feel the wind on the bike? Are you looking forward to owning your high-powered electric bicycle? Then you can’t miss our electric bike motor conversion kit. The conversion kit is made of high-quality sensor and brake handles with high sensitivity to protect your ride. This professional and reliable conversion kit is a good choice for you.
26 inch electric bike conversion kit 350w front wheel motor e bike kit 36v hub motor bicycle bldc26 inch electric bike conversion kit 350w front wheel motor e bike kit 36v hub motor bicycle bldc
Application
This bike conversion kit fits 26-inch bikes.
Detail
350 26 48 ebike kit ebike conversion kit electric bike kit motor kit front wheel ebike kit battery 350 26 48 ebike kit ebike conversion kit electric bike kit motor kit front wheel ebike kit battery
26 inch e bike kit 36v hub motor bicycle bldc controller bldc controller with lcd display controller26 inch e bike kit 36v hub motor bicycle bldc controller bldc controller with lcd display controller
Aluminum Rim
The rim of the electric wheel in this set is made of excellent aluminum, which is waterproof. The high-quality rim is more durable and extends its service life
Clear LCD Display
The LCD in this set is very clear. You can see the displayed speed, power, mileage, and other data very clearly
Two Types of Handlebars
This bike modification kit has two types of handlebars.In addition to the accelerator thumb handle, there is also a power brake handle
hub motor bicycle bldc controller with lcd display controller pas brake lever for 26 1.95 tire lcdhub motor bicycle bldc controller with lcd display controller pas brake lever for 26 1.95 tire lcd
hub motor bicycle bldc controller with lcd display controller pas brake lever for 26 1.95 tire lighthub motor bicycle bldc controller with lcd display controller pas brake lever for 26 1.95 tire light
electric bike conversion kit front wheel motor 350w e bike kit 36v hub motor 26 bicycle bldc controlelectric bike conversion kit front wheel motor 350w e bike kit 36v hub motor 26 bicycle bldc control
Pedal Assistant Sensor
The pedal assist sensor senses the rhythm of the pedal and adjusts the speed of motor rotation accordingly. You can get the power assist without holding the throttle as a way to avoid the wrist pain caused by constant pressure
Bright Light
The equipped light helps illuminate the road while you ride, you can be sure to feel the speed while having a full sense of safety
Controller Bag
This set is equipped with a controller bag, which can store the controller. It is not only very convenient to store it but also very good-looking
26 electric bike conversion kit 350w front wheel motor e bike kit 36v hub motor bicycle bldc control26 electric bike conversion kit 350w front wheel motor e bike kit 36v hub motor bicycle bldc control
High-quality Material: The motor wheel is made of good performance aluminum material that is strong and durable. Every part of the conversion kit is made of high-quality workmanship, which makes your bike safe and durableHigh Power: This electric bike conversion kit is equipped with a 350W brushless and tooth gear motor, which is powerful and can reduce noisePowerful Controller: This electric bike conversion kit is equipped with a powerful controller to ensure a high current supply. It can help you ride, double the distance, and make the riding process easierDiverse Functions: This product has a five-speed adjustable, and also with a fixed-speed cruise function. It can bring you an unprecedented riding experienceHigh-speed Riding: This wheel has a maximum motor speed of 35 km/h when it is unloaded, so you can enjoy the exciting experience of high-speed riding
Package Included
1* Motor Wheel
1* Controller
1* LCD Display
1* Ordinary Throttle
1* Pedal Assistant Sensor
1* Power-off Brake Lever
1* Light
1* Controller Bag
1* English Manual
All Accessories for Assembly
350 26 48 ebike kit ebike conversion kit electric bike kit motor kit front wheel ebike kit with bag350 26 48 ebike kit ebike conversion kit electric bike kit motor kit front wheel ebike kit with bag
Notes
Please make sure to use lead-acid or lithium batteries of the corresponding voltage.Please read the user manual carefully before use and pay special attention to the safety precautions included.It is suitable for two-wheeled bicycles, not for three-wheeled or multi-wheeled vehicles.Please allow the slight color difference caused by the shooting light and 1-3cm error due to manual measurement, and make sure you do not mind before you order.This set does not include tires and needs to be purchased by the customer. The suitable tire size is 26*1.75-2.125inch.
High-quality Material: The motor wheel is made of strong and durable aluminum, and every part of the conversion kit is crafted with high-quality workmanship, ensuring a safe and durable bike
High Power: Equipped with a 350W brushless and tooth gear motor, providing powerful performance while reducing noise for a smooth and quiet ride
Powerful Controller: Features a powerful controller to ensure a high current supply, helping you ride further and making the riding process easier and more enjoyable. This wheel has a maximum motor speed of 35 km/h when it is unloaded
Two Types of Handlebars: Comes with two types of handlebars, including a normal handlebar and a power-off brake handle, providing a double guarantee of safety
Diverse Functions and Real-time Display: Offers a five-speed adjustable setting and a fixed-speed cruise function, along with an LCD display showing speed, mileage, power, and fault information in real time, enhancing the riding experience and convenience
