Price: $39.99
(as of Aug 18, 2024 04:15:54 UTC – Details)
Product Parameters
Channel FM、AM、WB (WB band is only supported in the US) Frequency Range FM:76-108Mhz AM:520-1710Khz WB:162.4-162.55 SOS Support manual SOS alarm, support monitoring WB1050 signal automatic alarm Reading light 0.3W reading light, support CCT switching and brightness adjustment Battery Rechargeable lithium 18650 battery 2200mAh, or Max 7000mAh for optional Battery indicator Support 4 battery indicator lights (25%, 50%, 75% ,100%) USB output Support 1A output to charge mobile phone Charging method USB charging 5V/1.1A、0.6W solar charging、Hand crank charging Speaker 3ohm 2W Earphone output 3.5mm earphone output Working voltage 3.0V – 4.2V Working temperature -10℃ – 60℃ Max power consumption 1.55W
