200W Portable Power Station, Powkey 120Wh/33,000mAh Power Bank with AC Outlet, 110V 6 Outputs Solar Generator External Battery Pack with LED Light for Home Use and Outdoor Camping
Price: $149.99 - $102.99
(as of Aug 22, 2024 16:00:26 UTC – Details)
44
portable power stationportable power station
Powkey 120Wh Portable Power Station, 33,000mAh Power Bank with 110V/200W AC Outlet
3 Rechargeable Ways
The portable solar generator is equipped with a lithium battery pack that can be efficiently charged via:
15-24 volt solar panel (not included)——Connect to a 40W solar panel. The charging time is about 5-8 hours.
AC Wall Charging——Connect the adapter that comes with the portable power station to a wall socket. The charging time is about 4-5 hours.
12V car charging——Connect to a 12V cigarette lighter included in the package. The charging time is about 4-5 hours.
No memory effect, no need to worry about battery capacity reduction.
11
22
Specifications:
11
Battery Type: Lithium-ion Capacity: 120Wh (33,000mAh,3.7V) Bulb Type: LED Flashlight with 3 mode: Light, Strobe, SOS Lifecycle: >1000 Times to 80% capacity remained Working Temperature Range: 0°C – 40°C / 32°F – 104°F
Weight: 3.2 lbs / 1.45 kg
Dimensions: 7 x 5 x 5 in / 18 x 13.8 x 13.8cm
Input:
Charging Port: DC 5.5 x 2.1mm, 15V/2A
Output:
AC Output(x1): 110V, 60HZ; Modified Sine Wave, 200W max
DC Output(x2): 9~12.6V/10A max
USB Output(x2): 5V/3.1A
USB-C Output(x1): 5V/3A, 9V/2A
22
power station packagepower station package
power station R180power station R180
Safe Protection System
With advanced Battery Management System (BMS), R180 extends battery service life with protection of short-circuit / overvoltage / overload / overheating and ensures 1000+ lifecycles.
Package Contents
1 x 120Wh Portable Power Station
1 x Car Cigarette Lighter Adapter
1 x AC Power Adapter
1 x Car Charging Cable
1 x User Manual
Can NOT Support Devices Rated Over 200W
120Wh portable power station can charge your devices that operate power at less than 200W, such as smartphones, laptops, Mini fans, lamps, drones and more small appliances.
4.2 out of 5 stars
913
4.2 out of 5 stars
913
4.2 out of 5 stars
913
4.3 out of 5 stars
16
9
$102.99$102.99 $192.98$192.98 $275.54$275.54 $169.99$169.99 $229.99$229.99 $139.99$139.99
Rated Power
200W 350W 600W 200W,60W 350W,60W 200W,40W
Input
DC 5.5 x 2.1mm, 15V/2A DC 5.5 x 2.1mm, 19V 3.42A, 65W max DC 7.9 x 0.9mm, 19V/4.74A, 90W max DC 5.5 x 2.1mm, 15V-24V/2.6A DC 5.5 x 2.1mm, 12V-25V, 65W max DC 5.5 x 2.1mm, 15V-24V/2.6A
AC output
1 x 110V 60HZ Modified Sine Wave 2 x 110V 60Hz Pure Sine Wave 2 x 110V 60Hz Pure Sine Wave 1 x 110V 60HZ Modified Sine Wave 2 x 110V 60Hz Pure Sine Wave 1 x 110V 60HZ Modified Sine Wave
DC output
2 x 9~12.6V/10A max 12V 8A; 24V 3A 12V 8A / / /
USB-A output
2 x 5V/3.1A Total 5V 3.1A max A1:5V 2.4A, A2:5V 3A,9V 2A,12V 1.5A / / /
USB-C output
5V/3A, 9V/2A 5V 3A, 9V 2A C1:5V 3A,9V 2A,12V 1.5A C2:5V 9V 12V 15V/3A,20V/5A / / /
Item Size
7 x 5 x 5 in 8.7 x 6.3 x 6.3 in 10.6 x 8.1 x 7 in 14.6×9.8x2in(Solar Panel) 14.6×9.8x2in(Solar Panel) 13.6×9.8x2in(Solar Panel)
Item Weight
3.2 lbs 6.4 lbs 9.9 lbs 8.2 lbs 11.4 lbs 7.4lbs
120WH CAPACITY: The power station has a power capacity of 120Wh/33,000mAh which the camping power supply can power most electronic devices efficiently. It can fully charge mobile phone 10+ times, the laptop 2 times, the CPAP machine 3 hours (the time will be different according to the power of the machine), the led light more than 20 hours, and the mini refrigerator about 3 hours. Applicable for emergency situations such as hurricanes, off-grid camping, short blackouts, earthquakes
3 WAYS OF RECHARGING: This 120Wh portable rechargeable power station has 3 methods to get recharged. The package includes two adapters, you can charge it via wall socket or car adapter(12V). And it also can be recharged under the sun with a solar panel(15V-24V/2.6A)(NOT included)
EMERGENCY FLASHLIGHT&COMPACT HANDLE: The portable battery pack weighs only 3.2 lbs, and a comfortable and ergonomic handle makes it easy to take anywhere. This solar power station is built with dual white LED flashlight to meet your different needs. Press the flashlight button to switch on the light and single press the button to switch to blink/ SOS mode, Press the button again to switch off. When you go out camping or experience power outages, this power station may be a good choice
MULTI-OUTPUTS: The portable solar generator for home use is equipped with 1* AC outlet (110V 200W ), 2* USB ports (5V, 3.1A total),1* USB-C port , 2* DC Outputs(9~12.6V/10A) which can charge smartphone, tablet, camera, mini refrigerator, night light, mini fan, CPAP and other electronic devices under 200W
WHAT YOU GET: 1 x 120Wh Portable Power Station, 1 x Car Cigarette Lighter Adapter, 1 x AC Power Adapter, 1 x Car Charging Cable, 1 x User Manual, we also provide 7*24 hours customer service and 24 months product guarantee.so you can worry-free
NOTES: Limited Appliance Wattage<200W, such as lamp, Electric Fan, TV, Game Machine, etc. AC will shut down when the power station is short-circuited or power overloaded. Remove the device and the power station will return to normal from short-circuit or overpower protection in a few seconds. Repress the AC output button to switch on AC output again
