200W Portable Power Station, 102.4Wh/32000mAh Outdoor Solar Generator Backup LiFePO4 Battery Power Pack with AC/DC Outlet, In/Output PD 60W USB-C Outlet for Home, Camping, RV, Blackout, CPAP
Price: $279.98 - $99.99
(as of Aug 11, 2024 09:45:09 UTC – Details)
P200 Pertable power stationP200 Pertable power station
indoor & outdoorindoor & outdoor
solarsolar
BMS & MPPTBMS & MPPT
portableportable
packagepackage
Some Maintenance Tips
It is best not to charge the battery after it is completely exhausted, otherwise it may affect the battery life.If the battery power is completely exhausted, you need to use the PD charging port to charge it first, the smaller wattage current is better to wake up the battery.If the battery needs to be stored for a long time, the battery should not be overcharged. Please also charge it during this period, preferably once a month. Leaving it for a long time without using it or charging may cause battery loss and lead to battery failure.
4.0 out of 5 stars
377
4.0 out of 5 stars
377
4.0 out of 5 stars
377
$99.99$99.99 $199.98$199.98 $179.99$179.99
Wattage
200W 400W 300W
Capacity
102.4Wh 296Wh 296Wh
Pass-through Charging
MPPT
BMS
Output
60W DC, QC 3.0 USB, PD 60W, PD 18W, 200W(400W peak) AC 120W DC, 120W cigarette lighter, QC 3.0 USB, PD 65W, 400W(800W peak) AC 72W DC, 72W cigarette lighter, QC 18W, USB 10W, PD 27W, 300W(600W peak) AC
Item Dimensions
7.36″L x 2.7″W x 5″H 8.66″L x 5.5″W x 7.28″H 8.66″L x 5.5″W x 7.28″H
Item Weight
3 lb 7.3 lb 6.9 lb
【MULTI-OUTPUTS】-Equipped with 1 * 12V/5A 60W DC output, 1 * QC 3.0, 1 * USB, 1 * PD 60W, 1 * PD 18W, 2 * 110V 200W(400W peak) AC, PGYOB portable power station can meet your different using needs for both indoor and outdoor like phones, tablets, laptops, cameras, drones, fans, electric blankets, CPAP and many other devices.(Please make sure the combined devices are less than 400W).
【4 Ways to Recharge】-You can charge you power station through a PD charge adapter(package not includes) or use a DC 5521 to PD convert (package includes) to wall chrge at home. Or you can charge through car outlet(package includes) when having a rv trip or road trip or a DC charge adapter(package not includes) . Also, the solar power station can charging by solar pannel(pannel and cable not include) when you having camping fun in the wild.
【Light and Portable】- Our outdoor solar generator only weights 3lb, small size and light weight with a carry handle make it easy for you to take to outdoor activities like camping or hiking. 3 modes of LED light – light, SOS, strobe can meet your different emergency needs when you’re in the forest or at the seaside.
【MPPT and BMS】- Built in MPPT (Maximum Power Point Tracking Control), the solar portable generator can extract the maximum power from the solar panel. Advanced BMS(Battery Management System) and premium LiFePO4 battery ensures a long bettery life cycle. High techology gives you excellent using experience.
【What You Will Get】- 1 * PGYOB 200W portable power station, 1 * DC 5521 to PD convert, 1* car charger cable, 1* user instruction and one-year after-sale service. Any using problem or questions, please reach out to us, PGYOB will reply within 24 hours.(Note: Wall charger cable not included)
【Note】- If the battery needs to be stored for a long time, the battery should not be overcharged. Please also charge it during this period, preferably once a month and charge to 60%-80%. Leaving it for a long time without using or recharging may cause battery loss and lead to battery failure.
