200PCS Mini Split Rings Jump Ring 12mm Double Loops Keyrings Silver Metal Rings Connectors Keychain Flat Rings for Jewelry DIY Arts Ornaments Home Car Keys Attachment
Price: $14.89
(as of Sep 20, 2024 16:15:15 UTC – Details)
0101
Perfect connectors of DIY jewelry or handicrafts. A variety of colors, sufficient quantity!
Jewelry making jump rings are great for DIY your special & unique jewelry, Excellent for suspending small items,not easy to break or deform, anti-corrosion and anti-rust, can be kept for a long time use, their classic and the surface is also not easy to fade.
4.6 out of 5 stars
15
4.6 out of 5 stars
15
4.6 out of 5 stars
15
4.6 out of 5 stars
15
4.6 out of 5 stars
15
— $14.89$14.89 $14.89$14.89 $14.89$14.89 $14.89$14.89
strong and sturdy
WIDE RANGE OF APPLICATIONS
11
22
33
STURDY MATERIAL
Made of alloy, are durable, these small keyrings are sturdy and light weight, handy to use,split rings are smooth in surface,Each open ring comes with 2 layers design, keep them securely closed so that the attachments won’t slip off from the rings.
EASY TO USE
The design also allows items to be conveniently added or removedThe double loops of each ring are firmly closed for tight connection,no need to worry about your keys falling apart. They have sufficient tension to easily move items in or out of them without deformation.
DIY FAVORITE
Great for DIY your special & unique jewelry,It’s practial for making key ring pendant,bags pendant and other accesspries. You can use your imagination to DIY your own keychain, make pendant for phone, bag, purse,etc.
11
DOUBLE LOOP DESIGN
Polished round ring. Great workmanship with the ring, smooth surface and edge, will not scratch your hands and stuffs.These split key rings with double loops, provides extra secure hold in your jewelry-making projects.It’s practial for making key ring pendant,bags pendant and other accesspries,easy and convenient to carry.Handy to hold keys, luggage tags, ornaments or other items with holes.
11
DOUBLE LOOP DESIGN
33
DOUBLE LOOP DESIGN
44
DOUBLE LOOP DESIGN
11
Shiny Gold
11
Charming Rainbow
33
Commonly Used Silver
44
Special Rose Gold
33
The round flat split ring
With these small split rings, great for organizing your house keys, car keys, hang cards,dog tags,DIY accessories, making arts and crafts project and so on. Also intended to connect accessories to a larger key ring.
【Size】: Each ring is 0.47inch(12mm) in outer diameter 0.39inch(10mm) in inner diameter and 0.059inch(1.5mm) in thickness,small and lightweight.
【Color】: Silver
【Material】: The round keyrings are made of metal alloy which make them strong and sturdy.not easy to break or deform, anti-corrosion and anti-rust, can be kept for a long time use, their classic and the surface is also not easy to fade.
【Sufficient amount】: Total 200 pieces of keyrings,that will meet your needs for daily use or craft projects
【Fine workmanship】: Metal split rings are smooth in surface,Each open ring comes with 2 layers design, keep them securely closed so that the attachments won’t slip off from the rings, the design also allows items to be conveniently added or removedThe double loops of each ring are firmly closed for tight connection,no need to worry about your keys falling apart. They have sufficient tension to easily move items in or out of them without deformation.
【Wide Applicatiom】: The round flat split ring is good for Perfect for organizing your keys, hang cards, dog tags,DIY accessories, making arts project and so on. Also intended to connect accessories to a larger key ring.
