2000mAh SOS Alarm Emergency Weather Radio, 3LED Type-C Hand Crank Solar Battery Operated Wind Up Radio Flashlight, NOAA AM FM Portable Radio Cell Phone Charger Survival Kit (Red)
Price: $19.99 - $15.98
(as of Aug 11, 2024 05:30:14 UTC – Details)
NNOOAADIO WEATHER RADIONNOOAADIO WEATHER RADIO
solar crank radio solar crank radio
NNOOAADIO Weather radio will be upgraded in June 2022, with the same expenditure and higher performance.
In a hurricanes season, how to build your hurricane survival kit ?
Just buy an emergency weather alert radio to help you be full prepared before bad weather coming. This NOAA radio is specially designed for emergency needs.
We can’t stop the disaster, but we hope our emergency solar crank radio can accompany you through this difficult period and give you some help when the disaster comes.
NO POWER, NO LIGHT, CANNOT COMMUNICATE WITH OUTSIDE WORLD, and SO ON. How small and helpless we are while we meet nature. Emergency radio with 7 NOAA weather bands ,4 charging ways , 2000mAh power bank, 1W * 3 LED flashlight(Can be used as reading lamp) would be far more reliable than your cellphone in that situation.
All Features:
●SOS ALARM + Stroboscopic Distress Light
●2000 mAh Type-C mobile phone charger for both Lighting and Android devices.
(The battery is of replaceable design, which is convenient for self replacement after aging.)
●4 Ways to keep the radio be powered on and no worry about battery dead.
●7 NOAA channels to get latest weather and hazard information.
●NOAA Weather Alert to inform you at the first time when bad weather comes.
●Built-in retractable 5 antenna to enhance the signal, no longer worry aboutbad signals and missing news.
●1W *3 LED Flashlight is seriously bright- 100 lumen;
●Mountaineering buckle can hang the machine inside the tent and turn it into a temporary chandelier.
solar flashlightsolar flashlight
noaa weather radionoaa weather radio
shortwave radioshortwave radio
Integrated Power Bank Keeps Your Devices Powered in an Emergency
A 2000mAh power bank provides enough emergency power to any mobile device in emergency situations. Works with most Type-C powered devices.Built in SOS alarm chip, press and hold SOS for three seconds to send out international distress signal (alarm sound + stroboscopic)
High Power Generator
600mah Super large current brushless generator, rotate quickly by hand for 6 seconds (regardless of direction), and the machine can be restored to use immediately.
4 Power Supply Modes
The solar crank emergency radio’s Li-ion batteries, a solar panel, USB Corded-Electric, and a crank lever provide full battery power. The solar panel and crank are regenerative, ensuring you have power whenever you need it.Note: the built-in rechargeable battery is of replaceable design (you can replace the battery with larger capacity by yourself)
battery powered radiobattery powered radio
solar powered phone chargerssolar powered phone chargers
hand crank radiohand crank radio
Specifications
Frequency Range: AM:520-1710KHz, FM:87-108MHz, WB(NOAA):162.400-162.550MHzDimensions: 5 x 2.4 x 1.8 inchesWeight: 230 GramsPower Consumption: 3W (MAX)Working Voltage: 2.7-4.2VPower Source: 2000mAh / 3.7V Li-ionWaterproof Level: IPX-3LED Flashlight: 1W * 3LED / 100LMManufacturer Part Number: HN-028SWB-1
3LED Light & Mountaineering buckle
NNOOAADIO’s emergency weather radio provides you with 3 LED light: You can use the climbing buckle to hang in the tent and turn it into a temporary chandelier;1W * 3 High light LED lighting any emergency situation.
Package Includes
1x Solar Emergency Weather Radio1x Mountaineering buckle + Adjustable hand rope1x Type-C Data Line1x User Manual
NNOOAADIO’s emergency radio will give you dependable access to emergency NOAA weather broadcasts. The AM/FM function provides full access to all AM or FM radio broadcasts.
NNOOAADIO’s Brand Commitment
– 60-Day Money-Back Promise;
– 30-Month Replacement Promise;
– Lifetime Customer Support Promise.
If you are not satisfied with the SOS emergency hand-operated power generation weather radio, please feel free to inform us.
We will provide 24-hour follow-up service to meet your needs.
Your satisfaction is our greatest achievement.
4 RECHARGEABLE WAYS — Hand crank powered radio, solar powered radio,5V Type-C charging input, and built-in 2000mAh battery powered radio (it takes 3~4 hours to fully charge), also providing emergency power bank for iPhone Samsung Google LG iPad, etc.
NOAA AM FM PORTABLE RADIO — AM has a larger receiving range than FM shortwave radio, but FM can receive entertainment, sports, talk shows and news more clearly within tens of kilometers. (WB) NOAA weather radio receives 7-channel real-time weather forecasts (US and Canada only), such as earthquakes, hurricanes, tornadoes and strong storms.
EMERGENCY RADIO POWERFUL — Built-in 3 LED emergency flashlight, Essential camping supplies & hurricanes earthquake emergency survival kit; also a solar charging indicator, a channel signal light.
EMERGENCY SURVIVAL KIT DETAIL — Telescopic antenna extends up to 30cm for high sensitivity reception assisted by advanced semiconductor circuitry design and LED signal strength indicator for pin-point tuning accuracy, and the built in ‘SOS + stroboscopic’ chip can send effective distress signals, It also comes with a lanyard.
WEATHER RADIO WARRANTY — We pass CE FCC ROHS & Standardization ISO 9001. Also, provide unconditional free return service within 60 days, please rest assured to buy products. Brand: NNOOAADIO.
