Price: $35.90
(as of Sep 21, 2024 15:30:17 UTC – Details)
MD-098 Emergeny Retro Weather Radio
Compared With the other emergency weather radio in the market, the MD-098 emergency radio has been made a lot of upgrade:
With the upgraded DSP chip and external antenna, 7 NOAA Weather channel could be received clearly, the radio signal is strong and stable;Equipped with a 2000mAh built-in battery in the portable size , convenient for carry or as the emergency power bank for your cell phone while you are camping;Equipped with Bluetooth 5.0 and an excellent stereo bass, Works excellent as the bluetooth speaker;1W Bright flashlight could light up your around so that you’re not afraid of darkness;Retro style design with TF card slot and earphone Jack, enjoy your lessure time yourself.
2000mAh Emergeny Power Bank
This emergency crank radio equipped with a 2000mAh built-in battery, which could provide the emergency power for your cellphone while you’re run out of the electricity
Bright Flashlight Radio
Equipped with a 1W flashlight, the flashlight radio could light up your around to dispel the darkness. This solar crank radio is your great choice for your outdoor activity, such asn camping,hiking or others.
Portabl Radio for Hiking
With the pocket size: 2.64*4.61*2.62 inches and the weight is 0.57 pounds, the portable weather radio is small enough to put in the bag, convenient for carrying when you move around.
The Specification Of AM FM Radio
– FM : 87~108MHz
– AM : 520 ~ 1710KHz
– WB : 162.550 ~162.400MHz
– Working Voltage : 2.7V~4.2V
– Maximum Power: About 9W
– Waterproof : IPX3
– Speakert : 4Ω3W
3 Power Charging Options
-An Emergency Retro Style Weather Radio
Micro USB – To fully charge the emergency radio just about 4 hoursSolar Power – Mainly protect the rechargeable batteryHand Crank – Spin 1mins can be used for light 30mins or radio for 6mins.
Bluetooth 5.0 & Earphone Jack
Different from the other emergency radio on the market, the MD-098 emergency weather radio make integrates emergency function with a bluetooth speaker perfectly:
– Bluetooth & TF Slot: Equipped with Bluetooth 5.0, this retro emergency radio could quickly connect to your phone or another electrical device less than 1s to play your favorite music; Meanwhile, the emergency crank radio with the Bluetooth speaker also supports the TF card( not included) below 32G. Enjoy your music world!- Earphone Jack: Comes with a 3.5mm earphone Jack, ideal for you to put on your headphones and enjoy your leisurely private time.
SELLER PROMISE
– 30-Day Money-Back Promise;
– 18-Month Replacement Promise;
– Lifetime Support Promise.
Your voice drives us to be the best. If you are not satisfied with this NOAA weather radio, we can refund you immediately as you email to us. And we are in here for you 24/7 for anything you need!
1W Flashlight and emergency weather information plus a dependable power source will prove to be invaluable in the face of mother nature’s fury!
As a responsible Brand , We Always be with you to defeat the monster disasters.
Always Be Prepared for the Worst but Hope for the Best! – Scroll Up to Click to Purchase
【Portable Emergency Weather Radio】With the upgraded DSP chip and external antenna, this emergency weather radio could dependably receive the emergency weather forecast and emergency news broadcasts from NOAA and AM/FM stations, such as hurricanes, tornadoes wildfires, winter storms and etc. Also, with a retro style and pocket size:2.64*4.62*2.62 in, this emergency radio is great for carrying or keeping at home. Keep this one in your home, to be well-prepared before disaster strikes.
【Retro Speaker】Equipped with an excellent stereo bass, this AM FM radio could work excellent as a speaker, which could connect quickly to a device such as your phone or other electronic devices within 30 feet, to play your favorite music crystal clear. Meanwhile, the retro crank radio also can recognize up to 32G TF card playback and supports a 3.5mm earphone Jack, allowing you to feel the surging of music as if the sound is on the scene.
【2000mAh Emergency Power Bank】While we were trapped in the power outage, the emergency weather radio with a 2000mAh emergency power bank would be far more reliable than the others device, which could provide enough sufficient emergency power for you to make important calls to your family or call for help. Meanwhile, the emergency radio is equipped with a 1W bright flashlight that could brighten the darkness around you, to get help faster. Keep one in your bag, let you away from danger.
【3 Power Charging Options】This emergency NOAA weather radio with 2000 mAh lithium-ion rechargeable battery, which not only could be charged via the Micro USB Cable to keep the playback time of the solar crank radio up to 16 hours. The Hand Crank and Solar Panel also could provide enough power to keep the crank radio on until the power back. Meanwhile, the 4 electric label allowing you to track remaining power at any time clearly. Never lost the electricity during the emergency!
【No Risk For Your Purchase】In the past years, Our emergency radio has helped more than 10,000,000 USA Civilians to live through the hurricane, tornadoes and snowstorm season, like “Dorian”, “Harvey, “Irma”, etc. Your voice drives us to be the best. We back our emergency weather radio with 18-months Warranty! If you are not satisfied with this NOAA weather radio, we can refund you immediately as you contact us. And our customer service is here for you 24/7 for anything you need!
