20″ Front/Rear Wheel Hub Electric Bike Conversion Kit, 36V 250W/48V 1000W E-Bike Powerful Hub Motor Kit with SW-810LED Display Waterproof Wire Front/Rear Wheel Hub Assembly Motor Kit (US Stock)
Price: $189.99
(as of Sep 30, 2024 09:00:14 UTC – Details)
Notes:
This product does not have tires, the kit is suitable for installing 20-inch tires.
while connecting the controller to the wires, please make sure that you connect the right colors to the controller. Otherwise, the controller may be broken.
About the battery: The power and voltage of the batterynot included you buy should be consistent with our set. When installing, make sure that the wiring is not reversed.Otherwise, it may damage the product.
Not waterproof, please do not drive on rainy days
Features:
1. 36V 250W Brushless toothed motor specification, strong and powerful.
2. Come with powerful controller guarantee big current supply.
3. Suitable for both V brake and Disc brake.
4. The maximum speed of the motor will be 30km/h (18.64 mi/h).
5. The open size of the front fork is 100mm
6. Thumb Throttle
7. The size of the rim is 20″Suitable for 20 inch bike.
8. Crank speed sensor for pedal assist.
Specifications:
Optional Type: Front Motor
Motor Specification: 36V 250W
Speed: 30KM/H (18.64 mi/h)
Front fork open size: Approx. 100mm / 3.9in
Brake: V brake/disc brake
Controller: 36V 15A
Assist: 5 magnetic point assist sensor
Brake Lever: Power cut-off brake lever
Throttle: Thumb Throttle
Display: SW-810LED Display
Wiring Mode: Waterproof wire for outgoing motor, common wiring for other
Package List:
1 * Motor
1 * Controller
1 * Assist
1 * Electronic power brake
1 * Thumb Throttle
1 * LED Display
1 * Waterproof Wire
1 * Controller carrying case
★FEATURE – 1. 36V 250W Brushless and toothless motor specification, strong and powerful. 2. Come with powerful controller guarantee big current supply. 3. Suitable for both V brake and Disc brake. 4. The maximum speed of the motor will be 30km/h (18.64 mi/h). 5. The open size of the rear fork is 135mm /5.3 in 6. Thumb Throttle 7. The size of the rim is 20″(Suitable for 20 inch bike). 8. Crank speed sensor for pedal assist.
★NOTE – While connecting the controller to the wires, please make sure that you connect the right colors to the controller. Otherwise, the controller may be broken. About the battery: The power and voltage of the battery(not included) you buy should be consistent with our set. When installing, make sure that the wiring is not reversed. Otherwise, it may damage the product.
★SPECIFICATION -Optional Type: Front Motor /Motor Specification: 36V 250W /Speed: 30KM/H (18.64 mi/h) /Front fork open size: Approx. 100mm / 3.9in /Brake: V brake/disc brake /Controller: 36V 15A /Assist: 5 magnetic point assist sensor /Brake Lever: Power cut-off brake lever /Throttle: Thumb Throttle /Display: SW-810LED Display
★PACKAGE LIST – 1 x Motor 1 x Controller 1 x Assist 1 x Electronic power brake 1 x Thumb Throttle 1 x LED Display 1 x Waterproof Wire 1 x Controller carrying case
