2 Pcs Smart Water Bottles with Digital Temperature Display Coffee Tea Infuser Bottle LED Thermal Cup Double Walled Vacuum Insulated Stainless Steel Flask Leak Proof Travel Mug Keep Warm (Black, White)
Price: $18.99
(as of Aug 12, 2024 00:00:20 UTC – Details)
11
33
44
Smart Temperature Display: each of these smart water bottles has a waterproof LED display with low energy consumption, no need to replace the battery, and will last for years, please gently press the top of the bottles, and the sensitive capacity touch cover can instantly display the water temperature in the bottles, avoiding embarrassing burns
Easy to Clean: the structure of the vacuum insulated water bottle with tea infuser is simple, if you want to clean it, you can just open it and wash it with a bottle brush, and the infuser can effectively hold the tea leaves and other solid residue, convenient for you to clean it
Stainless Steel Material: the inner wall and the outer shell of the tea infuser bottle is made of 304 grade stainless steel, also have silicone bottoms, designed to keep from slipping and spilling, no worry about the oxidation and corrosion, and won’t leave a metallic taste or rust easily, avoiding changing the taste of drinks (such as tea, coffee, and juice), which are safe and healthy to use
Leak Proof Design: the 500 ml double walled water bottles are designed to reduce spilling and shaking, as a leakproof silicone ring is embedded on the inside of the lid, so the bottle is safe in the bag when you go outside; And the about 17 oz/ 500 ml water bottle fits most cup holders and fits easily in a bag for travel
Versatile and Portable: you can take this portable tea infuser travel mug easily while hiking, biking, shopping or leaving it at home or office, fitting many places in many temperature conditions, your cold drink will stay chilled for up to 12 hours, or your coffee or tea will stay hot for up to 8 hours, just enjoy your drinking time with our bottle with temperature display
