2 Pack Waterproof Lighter Torch Lighter Outdoor Dual Arc Electric Lighters USB Rechargeable Windproof Plasma Lighter with Flashlight Flameless Camping Hiking Adventure Survival Tactical Gear
Price: $15.98
(as of Sep 04, 2024 23:15:12 UTC – Details)
outdoor lightersoutdoor lighters IP56 Waterproof Lighter with Flashlight
outdoor lighters 3 Modes Flashlight
3 modes: Low light (0.4W) ,High light (0.9W),Strobe light
The brightest light reaches up to 250 feet
camping lighter Perfect Use with One Hand
Size and weight: 3.0” x 1.9” x 0.7” , 0.15 lb
outdoor lighters 11.8 Inches lanyard
You can hang it around your neck,wrist for better carrying during camping, hiking, traveling
1 flashlight lighter 2 Pocket Size 3 Come with a lanyard
Remove the Casing Step 1
Take the lighter out from the waterproof casing, then you will see the refilling hole on the bottom. Refill by Butane Gas Step 2
Push filling hole to release all air.Shake gas can several times.Insert buane tip , press 2-3 times. Adjusting Flame Size Step 3
stablize the inner gas for 5-10 minutes.Then adjust the flame size according to your needs. Press and Get Fire Step 4
Finally you will get a powerful jet flame.
How to Refill a Torch Lighter ?
1 Remove the Casing 2 Refill by Butane Gas 3 Adjusting Flame Size 4 Press and Get Fire
Put the Buckle Down Step 2
You should put the buckle down first, or you can’t open the protecting cap. Open the Lid Step 2
Press the lock button, the lid will open automatically. Recharge with Cable Step 3
Use the charging cable to connect the lighter to the power supply for only 1.5 hours. Get Stable Dual Arc Step 4
Press the ignition button, then you will get dual arc.
How to Use a Usb Arc Lighter ?
1 Put the Buckle Down 2 Open the Lid 3 Charge by Usb Cable 4 Get Dual Arc
Multipurpose Lighter ourdoor lighter Electric arc lighterourdoor lighter Electric arc lighter ourdoor lighter Electric arc lighterourdoor lighter Electric arc lighter ourdoor lighter Electric arc lighterourdoor lighter Electric arc lighter ourdoor lighter Electric arc lighterourdoor lighter Electric arc lighter
outdoor lighteroutdoor lighter 2023 New Outdoor Lighters
Package Included: 1 USB Arc lighter + 1 Butane lighter + 1 usb cable + 2 Lanyards.
Do not place the lighter in the reach of children.Do not ignite the lighter around flammable and explosive materiels.Do not ignite the lighter for a long time(no more than 15 seconds)Do not refill lighter near fire sources and make sure the flame is extinguished after using.
Comparison on ZOOCURA Store
4.3 out of 5 stars
25
4.5 out of 5 stars
278
4.1 out of 5 stars
4,744
4.3 out of 5 stars
316
3.9 out of 5 stars
159
984
4.2 out of 5 stars
2,045
$26.99$26.99
$13.99$13.99
$12.99$12.99
$24.99$24.99
Flame Type
Single Flame + 360° Dual Arc
Double Flame
Double Flame
Single Flame
Triple Flame
Triple Flame
Double Flame
Visible gas window
Refillable
Adjustable Flame
Windproof
Fuel type
Butane + Electric
Butane
Butane
Butane
Butane
Butane
Butane
Material
ABS and Zinc Alloy
Copper, Zinc
Metal, Zinc
Zinc alloy
Copper
Brass, Ceramic
Brass
🏕️【2 PACK OUTDOOR LIGHTERS 】Package Included: 1 USB Arc lighter, 1 butane lighter, 1 usb cable and 2 Lanyards. The usb chargeable lighter is a perfect outdoor adventure tool. The butane torch lighter is a better choice when you need to burn thicker branches or wood. The 2 outdoor lighters can be used as a fire starter,camping gear,survival tool.
✅【USB ARC LIGHTER WITH FLASHLIGHT】No need to change any batteries! The flameless lighter is powered by a rechargeable battery. Use the attached cable to charge the electric lighter anywhere (computer, power bank, car..) via the USB port. It will take 1 hours for full charging and will stay charged for up to a week.The bottom of the arc lighter has a flashlight with three modes (strong light, low light, strobe mode).
🔥【REFILLABLE GAS LIGHTER】The torch lighter can be filled with butane gas repeatedly. The butane lighter can create 2800°F jet flame up to 1.8 inches. You can turn gas valve to “+” or “-“ to adjust flame length. (NOTE!!!Due to shipping safety regulations, the lighter is gas empty when you received)
🌊【WATERPROOF & WINDPROOF】These 2 lighters are also built with metal-ring sealed cover and locking clasp. IP56 Waterproof System allows them work well in rainy day and windy day. The arc lighter’s flameless design and the blue jet flame lighter both have a function of wind resistance.
🎒【PORTABLE & DURABLE】The compact size of both lighters (1.9”*3.0”*0.7”/ 0.15lb) is perfect for on-the-go use. Easy to carry and small enough to put in your pocket, handbag. This lighter body is made of high quality silicone rubber/ ABS and Zinc Alloy. The lightweight tool should be in every camper, hiker, hunter, fisherman and outdoors person’s pack.
💌【100% RISK-FREE & 1-YEAR WARRANTY 】Our product comes with 1-year Warranty. If you have need any help, please contact us.
