2 Pack Waterproof Lighter Outdoor Windproof Torch Lighter Dual Arc Lighter Butane Electric Lighter USB Rechargeable Lighter Flameless Plasma Lighter
Price: $15.98
(as of Sep 10, 2024 17:15:14 UTC – Details)
USB ARC LIGHTER CAMPINGUSB ARC LIGHTER CAMPING
Laffizz Multfunctional Lighter
camping survival gear lightercamping survival gear lighter
WHAT YOU CAN GET – Package included: 1 usb ARC lighter + 1 butane torch lighter, 1 usb cable and 2 Lanyards. The usb chargeable lighter is a perfect outdoor adventure tool. The refillable butane torch lighter is a better choice when you need to burn thicker branches or wood. Come with a lanyard for better carrying during camping, hiking, traveling
WATERPROOF & WINDPROOF – These 2 lighters are also built with metal-ring sealed cover and locking clasp. IP56 Waterproof System allows them work well in rainy day and windy day. The arc lighter’s flameless design and the blue jet flame lighter both have a function of wind resistance. A necessary tactical gear for the outdoors
USB RECHARGABLE LIGHTER – The flameless dual-arc lighter is powered by a rechargeable battery that can be used up to 300 times on a single charge. Includes USB charging cord, this quick charge battery will reach a full charge in only 1.5 hours and will stay charged for up to a week
REFILLABLE GAS LIGHTER – The torch lighter can be filled with butane gas repeatedly. The refillable butane lighter can create a single jet flame up to 1.8 inches with a temperature of 2800°F. You can turn gas valve to “+” or “-“ to raise and reduce flame length. (NOTE: Due to shipping safety regulations, the lighter will not be filled with butane when you received)
PORTABLE SIZE& DURABLE – The compact size of both lighters (1.9”*2.7”*0.7”/ 0.15 lb) is perfect for on-the-go use. Easy to carry as a survival kits and small enough to put in your pocket, handbag. This lighter body is made of high quality silicone rubber/ ABS and Zinc Alloy. The lightweight tool should be in every camper, hiker, hunter, fisherman and outdoors person’s pack
