2 Pack Candle Electric Lighter, USB Rechargeable Arc Plasma Windproof Portable Flameless Lighter, No Fuel Needed, Sleek Design, Triple Safety, Perfect for Kitchen Camping Xmas, Blue+Gold
Price: $6.99
(as of Sep 04, 2024 17:15:13 UTC – Details)
2 pack candle lighter cute2 pack candle lighter cute
sleek cool design lightersleek cool design lighter
NO FLAME – NO FUEL – NO GAS – NO HARM – PORTABLE DEVICE
Electric lighter use cleaner power than old fashion fuel-based lighter. Just plug into powered charging port and take it everywhere. Pocket size makes it easy to carry and use anytime anywhere. Let you get away from fire burn and spark.
Perfect for Candle
It’s also a kitchen lighter, arc lighter, plasma lighter, usb lighter, camping lighter, barbecue lighter, fireplace pilot lighter.
usb rechargeable lighter lytownusb rechargeable lighter lytown
electric arc lighter lytownelectric arc lighter lytown
candle lighter electric lytowncandle lighter electric lytown
bbq kitchen lighter usefulbbq kitchen lighter useful
Super Safety Chip
LYTOWN candle lighter has multi-protect safety system which ensures complete protection for you. For the safety of consumer, the igniting spark will auto stop beyond 7 seconds per igniting.
Windproof & Easy Maintenance
The tips are made of heat resistance ceramics (the ceramics do not burn). You can clean the tip parts of lighter with soft cloth. This design makes it work even in heavy winds.
Children Safety Button
Need to press the safety button and push up the switch SLOWLY/GENTLY to turn on the device. The safety button is to prevent the mistakenly touching.
candle electric lighter lytowncandle electric lighter lytown
LYTOWN Multi-Purpose Lighter
Whether you’re grilling at home, getting ready to warm up by the fireplace, lighting candles for a special occasion, LYTOWN lighters are there to light the way. Our Multi-purpose lighters are the essential tools for safe and convenient indoor and outdoor lighting needs. These high-performing, long-lasting lighters feature a durable wand to keep hands away from fire, have a child-resistant mechanism, and are 100% quality inspected.
Note
1.Be sure to press the safety button and push up the switch to start the lighter. For better using experience, please push up the switch gently then enjoy it.
2.This product will last for seven seconds after ignition, and will automatically turn off after seven seconds.
3.If you find the blue light is flashing, that means you need to charge it.
Specifications
Color: Blue
Material: Darual Zinc-alloy + ABS
Weight: 30g*2
Package Includes
2 x Electric Candle Lighter
2 x USB Charging Cable
Product Dimensions ‏ : ‎ 7 x 0.8 x 0.45 inches; 1.06 ounces
Date First Available ‏ : ‎ July 31, 2020
Manufacturer ‏ : ‎ LYTOWN
ASIN ‏ : ‎ B086J18S5T
TREBLE SAFETY DESIGN – Our rechargeable candle lighter gives you treble protection, you need to press the safety button and push up the switch to ignite the lighter. For the safety of consumer, the igniting spark will auto stop beyond 7 seconds per igniting. Restart the switch, the igniting spark will be re-ignited. Please press the safety button and push up the switch gently while using it.
ECONOMICAL & POWERFUL BATTERY – No gas required, No fluid required, No flame. Our Arc lighter is equal to 300 disposable lighters. One-Time charge can last to more than 500 times’ use. At least can be charged over 600 times. Please charge and make sure it 100% full charged when you get it. Quick charger(≥5V/2A) is not acceptable for this lighter.
WINDPROOF & PLASMA TECHNOLOGY – The Arc lighter adopt flameless plasma technology to protect the electric pulse from being blown out by strong wind or wet weather, ensures easily use it under any weather conditions, perfect and safe for daily indoor and outdoor use. Can be used for lighting tall candle jars, gas stove tops, BBQ grill, camping, fireworks, etc.
ECO FRIENDLY & CONVENIENT – The lighter uses plasma tech to eliminate the need for this harmful chemical. During the ignition, there will be gentle sound of “ zee, zee”, which is high-voltage power generation, please use with relax. USB rechargeable instead of refueling your lighter or throwing it away and buying a new one, you just connect the USB cable to a computer or a wall outlet and recharge it.
EASY TO STORE & MAINTAIN – Never put it under the sun and splashing water. To keep it in clean and dry corner in your kitchen. We provide good qualifying item for our customers. Once you are not satisfied with our product, you get a guarantee that we would give you change or refund here.
