Price: $99.99
(as of Jul 30, 2024 12:15:19 UTC – Details)
Countries of application: Canada, United States, Mexico, El Salvador, Dominican Republic, Puerto Rico (United States), United States Virgin Islands
Note: Some areas have eliminated analog signals and can only accept digital signals, please check what signals your local area can accept before purchasing.
Portable TV, ATSC-compliant, can watch analog TV, digital TV and ATV
USB port, TF card slot, play content from USB flash drive, support 1080p video, MKV, MOV, AVI, WMV, MP4, FLV, MPEG1-4, 1080P MP3 video, video
Package List 1 x TV 1 x AV Cable 1 x Remote Control 1 x Antenna 1 x Suction Cup Mount 1 x Charger 1 x 12V Car Charger Cable 1 x Manual Use Method
1. Turn on the power switch
2. Turn on the TV, the first time according to the interface guidelines, select the country, language, automatic channel search.
3.After searching channels, you can watch normally.
Digital Television
Received channels: ATV 48.25mhz ~ 863.25mhz
Digital TV: VHF (50MHz ~ 230mhz)
Digital TV: UHF (474mhz ~ 862mhz)
Display: TFT-LED color
Audio output: 2 W (max.)
Built-in lithium battery capacity: 1800mah (included)
Screen size: 16:09
Resolution: 1920×1280
Remote control battery type: AAAx2 (not included).
Interfaces: antenna connector; AV input connector; AV output connector; headphone connector; HDMi connector; USB connector; SD card slot
【ATSC digital TV】This ATSC digital TV can be used for watching analog TV, digital TV and ATV.
【Powerful Function】USB port, memory card slot, play the contents of U disk drive, support 1080p video, MKV, MOV, AVl, WMV, MP4, FLV, MPEG1‑4, 1080P video MP3.
【High Sensitivity TV Tuner】High sensitivity tuner, support FM radio function, can enhance signal receiving ability.
【Built-In Rechargeable Battery】Equipped with 1800mAh, rechargeable lithium battery for outdoor, plus a stand, easy to use.
【Feature】Equipped with USB/ inputs for internal/external playbacks. You can also hook our mini TV to your DVD player.
Display type: LCD
Display size: 13.0 inches
