12pcs Metal Flat Key Rings, 1 inch Thick Round Split Keyring for Car Office Home DIY Keychains (Gunmetal)
Price: $7.99
(as of Aug 18, 2024 04:00:35 UTC – Details)
MELORDY 12pcs Metal Flat Key Rings for Car Home Office
key ringkey ring
KEY RINGKEY RING
DIY Key Rings
KEY RINGKEY RING Multiple color
You can choose suitable color to diy unique keychain. Our key rings are made of high-quality plating, not easy to fade.
Key Rings for Car Home DIY projects
MELORDY 1” Thick Round Split Keyring
Lightweight & Strong
Specifications:
Material: iron
Inner diameter: 1inch(26mm)
Outer diameter : 1.3inch(33mm)
Thinkness:2.8mm
Package includes:
12 pcs 1inch key rings
Smooth surface and edge, won’t scratch your items. The keychain are handy to hold keys, luggage tags, ornaments or other items. Novelty gift for your friends, family.
Detail Show
KEY RINGKEY RING
KEY RINGKEY RING
KEY RINGKEY RING
Thick and Durable
Our key rings are made of high quality iron, thicker than other regular key rings. Our key ring can be used for a longer time avoid frequent replacement.
Sturdy Material
Our key rings are made of iron, sturdy, lightweight and durable, won’t rust and fade easily.
Easy to use
The keyring is easy to connect clasps, charms, links and other ornaments; They have sufficient tension to easily hold items without deformation.
KEY RINGKEY RING
[ Sturdy & Durable ] – Our key rings made of high-quality iron with smooth surface and edge, not easy to fade. Light weight but enough strong to hold your keys.
[ Perfect Size ] – The inner diameter of the ring: 1 inch(26mm) Outer diameter : 1.3inch (33mm) Thinkness: 0.11 inch(2.8mm). Comes with 12pcs strong key rings that enough for daily using.
[Practical & Safe] – Our flat rings stay securely closed and no need to worry about your keys falling apart, lightweight and convenient to use.They have sufficient tension to easily hold items without deformation.
[ Widely Usage ] – These keyring are easy to organize different keys of home, car, office. You can also DIY your own keychain, make pendant for phone, bag, purse,etc.
[ Fashionable Accessory ] – These key rings have many different colors for you to choose. You can use them in your daily life, such as hang badge cards, and dolls, purse, backpack
