10”HD 1080P Wired Backup Camera Kit, Full/Split Screen Monitor with Loop Recording&Parking Lines, IP69 Waterproof Rear/Side Cameras Auto IR Lights Night Vision, for Truck RV Trailer (C104)
Price: $199.99
(as of Aug 13, 2024 11:45:18 UTC – Details)
Wired Backup Camera Monitor for RV Truck, with 10 Inch Monitor for Safety Driving
XrooseXroose
RV Backup Camera System Bring You a Different Driving Experience C104
10 inch Screen: Better visual experience than other size especially while monitoring four cameras at the same time. Loop Recording: Monitor Supports maximum 128GB storage. Save data such as accident and driving route.Colourful Night Vision: DSPS High speed processor to get a Great Night Vision. Infrared night vision backup camera, as clear as daylight.HD Waterproof RV Backup Camera: IP69 Waterproof Camera has 16 Infrared Lights, sharp CCD sensor with excellent night vision.
C104C104
Remote Control RV Backup Camera System
Within a certain distance, the screen could be switched on and off, switching the screen split screen mode, and the menu options could be selected, etc.
The remote control is added to break the distance limit to a certain extent, making the channel switching more convenient and free. At the same time, it also makes it possible to adjust the system functions in one more way.
This RV backup camera system is easy to control.
C104C104
Infrared RV Backup Camera-Colorful Night Vision
Xroose C104 wired rv backup camera system, the night view presented by the system is no longer just black and white, but also adds color to the image.
Compared to other rv backup camera system, C104 wired backup camera monitor has the excellent night vision with color, and the camera won’t make the picture overexposure and dark. Due to the use of ARM DSPS High speed processor, all the image is more clearer and natural.
C104C104
Full Peripheral Vision Coverage, Avoic Blind Spots
IP69 Waterproof Backup Camera has 16 Infrared Lights, sharp CCD sensor with excellent night vision. It brings the more stable and clearer image than the wireless product. Withstand -59°F~176°F extreme temperature and work well even heavy rain.
The four-camera system provides you with a full range of field of view needs, a true 360-degree no-view angle. Hard-wired devices give you stable, low-latency, real-time picture conditions.
C104 wired rv backup camera system Provide you a more convenient and safe environment while driving.
XrooseXroose
Record every detail of the driving process
The rv backup camera system comes with a 32 GB memory card, which could be set through the system to scroll recording. The maximum support expansion memory card is 128 GB.
4.2 out of 5 stars
4
4.8 out of 5 stars
13
3.4 out of 5 stars
8
3.5 out of 5 stars
8
System Attributes
Wired Wired Wireless Wireless
Monitor Size
10 inch 10 inch 10.1 inch 10.1 inch
Camera Amount
3 4 3 4
Night Vision
Record Functiuon
Remote Control
✔ Larger 10-inch Screen:Better visual experience than other size especially while monitoring four cameras at the same time. BSP battery protection mechanism with less power consumption. Suitable for Truck/ Trailer/ Tractor/ RV/ Box Truck/ Camper/ Motorhome/ Pickup, etc.
✔ 1080P Visual Experience: Advanced 3D noise reduction technology and 1080P image processor makes the picture more restored, won’t make the picture overexposure or too dark, won’t make the picture overexposure or too dark, making it more clearer and natural. ARM DSPS High speed processor to get a Great Night Vision.
✔ Durable Ultra HD Waterproof Camera: IP69 Waterproof Camera has 16 Infrared Lights, sharp CCD sensor with excellent night vision. It brings the more stable and clearer image than the wireless product. Withstand -59°F~176°F extreme temperature and work well even heavy rain.
✔32GB Loop Recording & Parking Lines : Included 32GB SD card, occupied 7-10mb per mintue, can keep recording for at least 40hours. Supports maximum 128GB storage. Save data such as accident and driving route. With parking assist lines to guide you when reversing.
Easy to Install: Supports 4 wired cameras input/Loop recording/ Format/ Rewrite/ 9 spilt screen display/ local playback/ mirror and rotate option. Please connect the Red wires to ACC, the Black connect the Metal (Ground), and other 4-pin wires to the cameras as Instruction showed. We can also provides the 13-pin extension power cord if you need.
