1080P FHD Digital Wireless Backup Camera System Kit for RV/Truck/Trailer/Van/Bus,Night Vision,7inch HD LCD Monitor,IP69 Waterproof Rear View Camera No Interference Record-HW02
Price: $599.98 - $239.99
(as of Aug 08, 2024 22:00:16 UTC – Details)
Monitor Installation 1. Connect the rear view monitor to cigarette lighter socket 2. Turn on the monitor switch Camera Installation 1. Connect the black wire of the camera to negative pole,red wire to DC12V or DC24V voltage. 2. If you connect it to taillight, it will work when reversing. If you connect it to running light, it will work when reversing. Technical Specification Monitor: Screen size: 7-inches Power: DC12V-24V Lens Viewing Angle: 149 Degrees Resolution: 1920×1080 – RGB Operating Temperature: -25 ~60 degrees centigrade Backup camera: Processor: Digital FHD image processor with CCD Video output : RCA connector, 1. 0vp-p, 75ohm Waterproof IP Rate: IP69K Operating Temperature : -25 to 60 degrees centigrade Package Includes: 1 x 7-inch LCD Monitor 1 x Rear view Camera 1 x Cigarette Lighter adapter with on/off 2 x Power cord 2x TV Antenna 2x Installation kits 2 x Fixed Bracket kit 1 x Sunshade 1 x User Manual
🔅【Fourth Generation Signal】4th Generation Digital Signal,120ft No Delay. Transmission Rate Reaches 7200bps. You can Observe the Stay Smooth and Clear Road Conditions in Real Time even at 85 Mile High-Speed. “Wireless” means that there are no cables between the cameras and the monitor. Just connect the camera to the monitor via wireless signal. The cameras and the monitor need to be plugged in for use.
🔅【HD 1080p and Record Video】Advanced AIST Technology to Generate HD Images,Built-in 32G memory card for recording video.And You Can Play Video on Monitor.Making Your Receiving More Confident and Safe.
🔅【Multi-function View】This system support up to 4 cameras, it can be Freely Switched to Single View Dual View or Quad View(CH1/CH2/CH4). Dimension of the camera (without bracket): 2.95inch(L) * 2.36inch(H) * 1.85inch(W)
🔅【Night Vision and IP69 Waterproof】CCD Sensor for Rear Camera.Make the Night Vision Images More Clear and Stereoscopic.Accurately Identify Lawns, Lakes, and Stones even in the Dark.The Camera Outer Casing is Closed with a Metal Gel. Anti-fog and Waterproof.
🔅【Easy Installation and Wide Application】There is a Graphic Manual and Install Video in the Kit.12-24V DC Voltage Range From To Accomodate a Wide Variety of Large Vehicle as RV/Camper/Truck/5th Wheel Trailer/Bus/Van/Pickup.
🔅 Please note that the system transmits the camera image to the monitor via a wireless 2.4GHz signal. There is no cable between the camera and the monitor, but the camera and the monitor need power cord to get power and work, which saves yourself the trouble of charging and provide convenient and safe monitoring for your travels.
