1080P Backup Camera System 4 Split Screen Front Rear Side Reversing Camera 10.36 inch Touchscreen Monitor Kit Driving Recorder FM Transmitter Bluetooth Music USB Play Parking Monitoring
Price: $139.99
(as of Aug 18, 2024 18:15:15 UTC – Details)
radioradio
radio
DVR recording function, which supports simultaneous recording and automatic loop coverage.
Sound Synchronization
The sound of the player can be emitted from the original car horn.
ParkAssist
The height and width of the reversing line can be adjusted.
Bluetooth & USB input
Supports Bluetooth played music, or inserts a U disk to play music or watch videos.
Full Color HD Camera
Full-color HD camera, low-light night vision.
1 Auto Loop Recording 2 Sound Synchronization 3 Park Assist 4 Bluetooth & USB Input 5 Full Color HD Camera
screenscreen
10.36” HD Full View Digital IPS Screen
Screen Brightness 500CD/M2, The Clearest Video Image Effective pixels of the Screen 1600*720P Video Recording Support MAX 128GB SD Card Power Supply Voltage DC9V-36V Signal Format PAL/NTSC Record Resolution 2K/4K Picture Mirroring front/back/lest/right can be chosen Camera System 720P/1080P, PAL/NTSC Parking Monitoring off/1/3/5/8/24 hours Screen Saver off/1 min/5 min Language Simplified Chinese / Traditional Chinese / English / Portuguese / Russian / Spanish / French / German / Italian / Japanese / Korean / Vietnamese / Turkish
Effective Pixels 1920X1080P Night Vision Color Resolution 720P/1080P Angle 100°H/ 60°V Signal Format PAL/NTSC Video Output AHD Video Signal Waterproof IP67 Voltage 12V Lens Focal Length 2.8MM
carcar
packagepackage
【Auto Loop Recording, 4 Split Screen】Front and rear dual camera. Full-color HD camera, low-light night vision. The cameras have DVR recording function, which supports simultaneous recording and automatic loop coverage. Support 4 split screen. The memory card supports a maximum of 128G.
【Sound Synchronization】When the FM frequency of the monitor is adjusted to the frequency of the car radio, the sound played by the monitor can also be sent out on the car radio. This function is only used for sound transmission, the monitor cannot listen to FM stations.
【Reversing Assist&Parking Monitoring】Support the reversing auxiliary line display. Waterproof night vision camera, reversing image is clearer. Automatically switch the reversing image when reversing. Recording will automatically start when an object moves in front of the camera connected to the positive cable of your car’s battery.
【Bluetooth & USB input】This car monitor supports Bluetooth played music, or inserts a U disk to play music or watch videos.
【Built-in Speaker】The rear view monitor has its own speaker, which can emit sound. Note that when the monitor’s FM logo is on, the monitor’s own speakers cannot produce sound. The FM switch needs to be turned off.
【Installation Tips】You can install the camera in the front/rear/left/right directions of the car. The camera trigger wire is connected to the car power ACC and the positive/left turn light/right turn light/reversing light power.
