Price: $89.99
(as of Sep 30, 2024 04:30:15 UTC – Details)
【44 Tooth Bike Engine Kit】100CC Bicycle Engine Kit. Displacement: 100CC; Number of Teeth: 44; Mode of Engine: Single Cylinder, Air-cooling, 2-stroke; Ignition Mode: CDI; Maximum Speed: 45km/28mi/h; Fuel Consumption: 2.5L/0.66gal/100km; Fuel Number: #92, #95.
【Upgrades Bike Motor Kit】2 Stroke Bicycle Engine Kit come with a complete engine kit, 2-stroke 100cc single cylinder gasoline engine, CDI Assembly,Fuel Tank (with Valve),Carburetor Assembly,Exhaust Muffler,Clutch handle, Left Handle Grip,Twist-grip Throttle with Kill Switch,Clutch Cable,Throttle Cable,Chain,Sprocket,Chain Idler Pulley,Chain Guard,Mounting tools.
【Low Fuel Consumption】100CC Gas Motor Bicycle Kit. Perfect for upgrading from a regular bike to an electric bike, you can enjoy a faster ride. Low fuel consumption, 150 miles per gallon, very energy efficient and economical. Max. Load capacity:200kg(440lb),Top Speed: 45km/h(28 mi/h).
【High Performance Carburetor】100CC Motorized Bike Kit. Features: Choke lever on the handlebars, Main jet. (Can be re-jetted), Pilot jet, Copper oil needle , Idle RPM Screw, Idle Air Screw delivers more fuel with the choke on, instead of restricting air. Great for cold weather starts!
【Install Suggest】2 Stroke Engine. Comes with all needed accessories for easy installation. Equipped with detailed instructions, this instruction contains every detail of the assembly steps. If you are inexperienced or installing engine kit for the first time, please read our Video or any question contact us in time.
