1000W Peak Electric Bike for Adults, Colorful LCD Display Mountain Electric Bicycle – 26″x4″ Fat Tires, Up to 30MPH 65Miles Range, Ebike for Adults with USB Port Removable Battery & 7 Speed
Price: $1,299.00
(as of Sep 30, 2024 00:45:17 UTC – Details)
Saber Step-over electric bike for adults
Specification:
Motor: 1000W peak, 95 N.m, brushless hub motor
Battery: 48 volt 17.5ah li-ion battery with USB charging port. Battery waterproof IP64
Charger: Input AC110V-240V 2.5A, Output DC54.6V 2.0Ah Smart Charger
Controller: 48V 28A, IP67
Display: Colorful LCD display
Headlight/Taillight: 280 lm/30 lm
Brake: HYY series 180mm brakes
Transmission: gear shift system 7-speed
Front fork: Mozo suspension fork with lockout and adjustment
Frame: 6061 Aluminum frame
Ebike Weight: 78 lbs (36 kg)
Max Load: 330 lbs (150 kg)
Range: 33~65 miles (72~128 km)
Recommended Rider Height: 5’6″ ~ 6’6″ (168cm ~ 198cm)
Included: Battery, charger, pedals, assembly toolset, assembly guide, additional hardware, zip ties
Warranty: 1 Years
NOTE: This warranty only applies to the original owner of a Senada bike and is limited to the replacement of defective parts.
Kindly Reminder: We recommend recording your bike’s frame serial number as soon as you receive it, for future reference. The frame serial number is usually engraved on the head tube or bottom bracket. You can take a photo of the serial number for safekeeping.
【Provides Powerful 1000W Power Output】: The electric mountain bicycle is equipped with a high-performance 1000W peak motor, delivering a top speed of 30 MPH and a torque of 85 N.m, which provides strong and smooth power delivery, climbing 15° inclines effortlessly.
【Removable Lithium-ion Battery with USB】: The electric bike’s battery with a USB charging port is convenient for charging your cell phone while riding. The 840Wh (48v/17.5ah) battery capacity efficiently improves the range, stability, and safety of the e-bike, lasting up to 35-65 miles on a single charge.
【Upgraded Colorful LCD Display】: The saber electric bike for adults features a colorful LCD display that provides more robust data support and a clear display even in sunlight. It shows speed, battery charge, 5 pedal assist levels, travel distance, and more, making it easy to track your rides.
【Safety Reliable Riding System】: The e-bike for adults with an adjustable front fork suspension system for great grip, with matching 180mm front and rear disc brakes for quick and safe stops on most terrains. The sturdy rear rack holds a max of 25kg, allowing you to place the items you need. The bright headlight enhances visibility in the dark, improving safety while riding.
【All-Terrain Dominance】: Our fat tire electric bike fitted with 26″ x 4.0″ professional fat tires for excellent traction on slippery roads, matched with a front derailleur tourney 1-Speed and a rear derailleur tourney 7-Speed. It can traverse all sorts of terrain, including mountains, snow, beaches, rocky roads, and even urban jungles.
【Quality Assurance & Service Commitment】: The e-bike adopts a triangular aluminum frame that is very stable and strong, capable of handling up to 330 lbs, and suitable for riders ranging from 5’5″ to 6’6″. SENADA e-bikes provide a 12-month after-sales guarantee. If you have any problems with the e-bikes, please feel free to contact us. (Our warehouse is in CA, so you can receive the electric bike quickly.)
