Price: $39.99
(as of Aug 19, 2024 03:15:17 UTC – Details)
A Must-Have Emergency Kit
[10000mAh Large Capacity, Double or More than Average ๐๐บ๐ฒ๐ฟ๐ด๐ฒ๐ป๐ฐ๐ ๐ฅ๐ฎ๐ฑ๐ถ๐ผ] Year 2023 newest model of solar ๐จ๐ค๐ก๐๐ง ๐๐ง๐๐ฃ๐ ๐๐๐๐๐ค comes with super large capacity 10000mAh rechargeable Li-polymer battery, it will be efficiently fully charged within 8 hours by the included type-C cable. also work as portable dynamo ๐๐ข๐๐ง๐๐๐ฃ๐๐ฎ ๐๐๐๐ง๐๐๐ง for more than 2 phones and light up any emergency conditions during power failure, makes you feel confident that it will be quite helpful if either event occurs.
[NOAA ๐๐ฒ๐ฎ๐๐ต๐ฒ๐ฟ ๐ฟ๐ฎ๐ฑ๐ถ๐ผ Keeps You Secure, Sensitive Reception for ๐ผ๐ ๐๐ ๐๐๐๐๐ค with Tuning Indicator] Easily slide the button to switch from AM, FM or NOAA weather band,smoothly rotate the knob to tune the favoriate channel,extend the antenna and 360ยฐrotation for better radio reception. especially the extreme weather events that seem to be occurring frequently,have 7 NOAA channels on for hearing broadcasts,this survival radio will be an essential tool to have for emergency situations.
[4 Power Sources, Never be Inoperable for Lack of Power] it comes with a variety of independent power methods including hand crank, solar, rechargeable battery, and type-C charging cable connection. the fully charged 10000mAh battery can support for 90 hours of radio playing, or 35 hours of far and dipped beam flashlight, or 50 hours of reading lamp. even if internal battery runs out, it will be ๐๐ง๐๐ฃ๐ ๐๐ก๐๐จ๐๐ก๐๐๐๐ฉ or dynamo crank to recharge the internal battery, always keep electricity on!
[3 Modes Ultra-Bright 5W 700LM LED Flashlight & 5W 700LM Reading Lamp] The flashlight has 3 modes settings include far beam, dipped beam and mixed beam. flashlight with 20pcs COB LED dipped beam and 1 W far beam on the side, a reading light with 48pcs COB LED underneath the folding solar panel, compared to similar products, much brighter than the average ๐ต๐ฎ๐ป๐ฑ ๐ฐ๐ฟ๐ฎ๐ป๐ธ flashlight, light up in full darkness to keep you safe during emergency power cuts.
[Emergency ๐พ๐ง๐๐ฃ๐ ๐พ๐๐๐ง๐๐๐ง and 5 Battery Status Indicators] ๐ฝ๐ผ๐ฟ๐๐ฎ๐ฏ๐น๐ฒ ๐ฟ๐ฎ๐ฑ๐ถ๐ผ keeps your cellphone always online to get in touch with others during the emergency,package contains 1M type-C charging cable for fast fully charge the radio within 8 hours.Indicator lights on the front panel to let you know battery status anytime,the charging indicator will turn green when radio is fully charged.each blue indicator equals 25% battery capacity that conveniently know the electricity.
[Loud 115dB SOS Alarm & IPX4 Waterproof & Compass & Hand Strap for Easy Carry] SOS mode that makes an audible sound with flashing torch to alert others if you were to get separated or lost. nylon strap on top for easy carry and it is very comfortable to handheld for camping. additional compass is very helpful to identify the direction when get lost outside. rubber piece covers charge-in port & usb output port to keep dust and dirt out.
Package List: Weather Radio X 1, Compass X1, Strip X1, 1 Meter Type-C Charging Cable X1, User Manual X1
