10000mAh Emergency Radio Solar Hand Crank AM FM NOAA Weather Radio Portable Battery Powered Radio with Phone Charger,Camping Flashlight,LED Lamp,SOS Alarm for Home Power Outages Outdoor Survival Gear
Price: $79.98 - $39.99
(as of Aug 07, 2024 03:15:34 UTC – Details)
soalr emergency radiosoalr emergency radio
Gustermmy Survival Radio
Gustermmy emergency weather radio is a must have survival tool for any emergency situation.
gustermmygustermmy
About Gustermmy
Our goal is to provide our valued customers with the best quality products at the most reasonable cost.
At the same time, we also:
Focus on Product DesignFocus on Product QualityFocus on Product SuggestionValue Every CustomerValue Every CommunicationValue Every Details
for home & outdoor usage
solar radiosolar radio
crank radiocrank radio
⛺【10000mAh Large Capacity Built-in Battery for Emergency Power Outages】The weather radio comes with 10000mAh large-capacity rechargeable battery, 5-10 times more endurance than other outdoor emergency radio, has long lasting battery endurance than ever. After fully charged(8H), this solar powered radio with hand crank supports: Phone Charging(3-5 times), Radio(90H), Flashlight(87H), Reading Lamp(85H). No battery anxiety when emergency situation comes.
⛺【4 Ways to Power with Battery Indicator】The outdoor gadgets have 4 power options in case of power outages. Built-in 10000mAh rechargeable battery and 4 power indicators show the remaining battery, this portable AM FM radio will be effortlessly recharged via manual winding up handle/solar panel/type c charging cable(included). No matter what emergency situation you encounter, this solar crank radio can always provide endless power!
⛺【Quickly Get the Daily Forecast of NOAA AM FM Radio】The solar hand crank radio is not only an AM FM radio that you can enjoy favorite radio tunes, but also an emergency survival radio that broadcasts the latest weather and hazard information for your area, helps you to be well prepared for any unexpected disaster before it arrives. Equipped with a Flexible antenna to get strong reception even in poor signal areas.
⛺【Provide You with More Light Sources】The emergency flashlight radio provides you with 3 modes flashlight – Far Beam(1W), Dipped Beam(20pcs COB LED) & Mixed Beam(5W/700LM)for better vision at night. Also included a 48pcs COB LED reading lamp to provide ample lighting for play and reading. It’s a must to have some light backup if you reside in a location with frequent power outages.
⛺【10000mAh Emergency Battery Charger】The battery operated radio with upgraded 10000mAh large-capacity rechargeable battery can work as an emergency power bank to charge more than 2 electronic equipment. It’s a great alternative for outdoor enthusiastors and the best discrete survival tool you can take for all of your trips like camping, hiking or fishing.
⛺【Life Saver Weather Radio with Compass & SOS Alarm】When you’re in danger with body can’t move and cry for help isn’t loud enough, press the SOS button of this emergency hand crank solar radio, it will send out a 115dB SOS alarm and flashlight to catch the attention of rescuers. We also embedded a compass at the top of the product to orient yourself while on an adventure. All of these increase your chances of being rescued in the event of emergency.
⛺【HOME & OUTDOOR NECESSARY】The portable emergency weather radio for home outdoor survival is IPX4 waterproof and very compact for outdoor usage: weight 1LB & dimension is 6.2*3.1*2.3inch. Upgrade your emergency bag with Gustermmy best portable solar hand crank weather radio and phone charger, you won’t regret having it!
