10000mAh Crank Radio, Emergency Radio, Solar Radio, NOAA/AM/FM Weather Radio, USB Type-C Charging, Dynamo Radio, Polymer Battery, Torch & LED Reading Light, SOS Alarm, Compass for Camping green
Price: $79.80 - $39.90
(as of Aug 09, 2024 01:15:30 UTC – Details)
Leaton Weather Radio Leaton Weather Radio
Leaton emergency supply
Focus on emergency radio
Add it to Your Emergency Kits and Get Prepared AheadKeep Your Family Away from Hazard Weather!
leaton Emergency Radioleaton Emergency Radio
Leaton has been striving to deliver Outdoor Survival Equipment o help you do your best in your daily work or outdoor exploration. Including Emergency radio, Camping light, weather radio.
Creating quality products for you to conquer the night is the root of our business. Most importantly, our ultimate goal is to cheer you up in the darkest moments.
330 Emergency Weather Radio330 Emergency Weather Radio
10000mAh Emergency Radio
 3-mode torch  3-mode torch
Flashlight radio
3 modes flashlight
– Far Beam(1W),
Dipped Beam(20pcs COB LED) Mixed Beam(5W/700LM)
3-mode torch3-mode torch
Portable Hand Crank Dynamo Radio
Dynamo RadioDynamo Radio
Hand Crank radioHand Crank radio
solar radiosolar radio
Necessary for emergencies – built-in rechargeable battery with 10000 mAh for charging the mobile phone and tablet in an emergency, This emergency weather crank radio can reliably receive the latest emergency weather forecasts of NOAA and AM/FM radio stations , Emergency portable radio, a super bright torch with 3 modes, a reading lamp, SOS alarm, a hand crank and a solar panel for charging the battery. 48 LED Reading Lamp with 20 LED Flashlight
3 charging modes – the emergency radio with built-in 10000 mah Polymer Battery can not only be charged via a USB Type-C cable, but you can also power the emergency radio via the hand crank and solar panels to ensure that you can use the radio crank normally in an emergency.
Emergency torch and super loud SOS alarm: this solar radio has built-in 3 LED torch modes and 1.3 W reading light There is an SOS siren and Compass. SOS siren can trigger a loud alarm and can be heard far to quickly attract attention and seek help. Compass can help you not get lost.
You can quickly get the daily forecast by turning the knob instead of turning the knob up and down. FM / AM radio receives good reception (AM:520-1710khz, FM:87-108MHZ, NOAA:162.400-162.550MHZ).
Small and waterproof- it is small and handy (160 x90x 80 mm), a weight of 500 g, with IPX3 protected against spray water at an angle of 60°. It does not take up much space when stored, and you can carry it anywhere in any bag or handbag.
