Price: $629.95 - $229.99
(as of Aug 02, 2024 12:15:14 UTC – Details)
With Losuudy, safe driving is always in your control.
How many roads does a person have to travel,before you realize the importance of safe driving?
The answer is Losuudy.
Losuudy rearview backup camera system has focused on driving safety and travel convenience to make your travel easier and more enjoyable.
Whether it’s a long trip or a daily driver, Losuudy will always keep you safe and make your trip more enjoyable.
Losuudy Backup Camera System
【4CH AHD Monitor】It can add up to four rear view camera/side view camera/front view camera. It can be very effective to help you reduce the stress of checking blind spots while changing lanes, making safety confirmations, and inspecting goods in cars. ※3 cameras are included by default.
【AHD Backup Camera for truck】Make the installation of backup camera for truk/RV more diverse! All 3 Backup Cameras have night vision. At the same time, all of them use AHD high-definition technology to achieve 1080P high-definition picture quality.
【2.5D full touch screen】On this latest version, we use a 10.1 inch full touch screen with a whole 2.5D IPS panel. All physical keys except the power button are removed, and the overall design is simple, symmetrical and modern.
【Rear View Camera System】 That’s the change that 10.1 inch big screen Back monitors bring to us! Because the display area is much larger than other 5-inch and 7-inch monitors, even if you adjust the screen to a 4-segment display, you can see it clearly and work more efficiently.
【Recording and Playback】Truck Backup camera system has DVR recording function. it can also be connected to 12V-36 V range power source.In addition, this product supports 4 cameras for video recording at the same time, which allows you to record every pleasant trip you have made.
【Easy for Installation】 You only need to insert the cigarette lighter adapt into the cigarette lighter socket to supply power to the system and avoid the traditional complex power supply. You only need one cable to connect the monitor and camera, and then you can complete the installation after wiring.
【2-year manufacturer’s warranty】We provide 2-year manufacturer’s warranty.
