Price: $337.75
(as of Aug 12, 2024 07:00:28 UTC – Details)
2023 Newly 10.1 Inch RV Wireless Backup Camera – having a safe journey from now on!
NOTE: If you need the Furrion pre-wired adapter for installation, please get in touch with us, we will send it to you immediately.
SUPPORT UP TO 4 CAMERAS
For this system, you can mount 4 cameras on your RV/Truck:
One camera on the front, and another on the back. For 2 side cameras, just mount one on the left and one on the right.
They can help to reduce the blind spot effectively, as well as a good helper for backing up
Note:
Wireless means it don’t need to connect the camera and monitor with wires, the images transfer through digital signal. But the camera and monitor need to be connected to the power source separately.
Image Flip
The image flip function allows you to switch to facing view(front view), or images upside down(vertical flip)
Parking Guide Lines
It can help you reverse safely. You can turn on/off the guide lines as you need
IP68 Waterproof Camera
Durable metal cover cameras could work perfectly even in rain, snow weather
4.0 out of 5 stars
10
4.0 out of 5 stars
29
4.6 out of 5 stars
29
4.3 out of 5 stars
13
Monitor
10.1″ LCD 10.1″ LCD 10.1″ LCD 10.1″ LCD
Resolution
1920×1080 1920×1080 1920×1080 1920×1080
Loop Recording
Waterproof Standard
IP68 IP68 IP68 IP68
Split Screen
Single / Dual / Quad Split Single / Dual / Quad Split Single / Dual / Quad Split Single / Dual / Quad Split
Number of Cameras
4 1 2 3
SD card
32GB (included) 32GB (included) 32GB (included) 32GB (included) 32GB (included)
