【MFi Certified】iPhone Car Charger Fast Charging, Rombica 4.8A Dual USB Smart Power Cigarette Lighter USB Car Charger with 2Pack Lightning to USB Cable for iPhone 14/13/12/11/XS/XR/SE/X 8/iPad/AirPods
Price: $8.99
(as of Aug 09, 2024 09:15:20 UTC – Details)
RombicaRombica
RombicaRombica
RombicaRombica
RombicaRombica
RombicaRombica
RombicaRombica
RombicaRombica
RombicaRombica
RombicaRombica
【Equipped with Dual USB Smart Power】: Using highly efficient components and an advanced chipset, Rombica’s High-Tech Chip Technology is perfectly compatible with iPhone. Our intelligent power fast car charger can charging two iPhone devices simultaneously, Provide a maximum of 2.4A/12W if a single port is used and 4.8A/24W when dual ports are used. Our most advanced charging technology ever charges virtually iPhone at its fastest possible, the charging speed is directly increased by 4 times.
【2 Pack MFi Certified Lightning Cable】: Rombica’s Lightning to USB cable with latest C89 termina. This MFi-Certified lightning cable is compatible with the following lightning devices: iPhone 14/14 Plus/14 Pro/14 Pro Max/13/13 Mini/13 Pro/13 Pro Max/12/12 Mini/12 Pro/12 Pro Max/SE 2020/11/11 Pro/11 Pro Max/XR/XS/XS Max/X 8 7 6 5, iPad, AirPods. The MFi Certified Cable comes with surge protection and 56KΩ pull-up resistor for preventing excessive current maximize charging efficiency.
【Leading the Way in Smart Chip Tech】: Built-in intelligent power management chip and advanced temperature control system that match the current required by the iPhone device automatically while maximizing charging speed and efficiency. Features a Dynamic Temperature Sensor which actively monitors temperature, and a Power Tuner Chip which adjusts power output to safeguard your connected iPhone/iPad/AirPods device.
【Multiple Security Advanced Protection】: Certified by MFi, UL, ETL, FCC, CE, ROHS approve. Built-in MFi Certified Chipset provide overvoltage protection, battery protector and automatic chip recognition functions preventing your iPhone from over chargerd and overheating. Rombica’s exclusive all-new iActivePower safety system with overload protection to enhanced safe charging, Provides continuous temperature monitoring and output control to protect your connected iPhone/iPad.
【Premium Materials and Design】: The housing made of an aluminum alloy + ABS fireproof materials offers better scratch resistance, heat dissipation, attractive design, and long service life, perfect for the most untouched vehicle interiors. Gold-plated tubing reduces heat during charging while maximizing charging speed and efficiency. The ring LED indicator can help you to find the charging ports easily in the dark, Easily fits in a car cigarette Lighter socket with limited space.
