Price: $399.98 - $159.99
(as of Aug 20, 2024 22:00:26 UTC – Details)
ZEROXCLUB B701 Wireless backup Camera System
Monitor adopts Capacitive Button, different from traditional one, it can react more sensitively, Anti-static, better waterproof, besides it looks more pretty. High quality color and clarity make your driving and reversing safer.
Full HD graphics helps you view the surroundings in real time.
When you leave the B701 backup camera system on as you travel to help with blind spots and just keeping track of the traffic behind you.
1 Product List 2 True Evaluation 3 Dimensions 4 Easy installation
ZEROXCLUB Wireless Backup Camera Kit: Trusted by Millions of Customers!
7‘’ Capacitive Button Monitor
1920×1080
7‘’ Press Button Monitor
1920×1080
10‘’ Press Button Monitor
1920×1080
Spilt Screen & Multiple Views
Support single view, dual view and quad view.
Support single view and dual view
IP69k Waterproof
Anti-fog and waterproof, suitable for Changeable weather.
IP69k Waterproof
IP69k Waterproof
Parking Guide Lines
Help you predict parking distance and reversing safely.
Parking Guide Lines
Parking Guide Lines
Compatible Vehicles
RV/Camper/Truck/Trailer/5th Wheel Trailer/Bus/Van/Motorhome/Farm Mach···
Compatible Vehicles
Compatible Vehicles
☆【Upgrade Digital Wireless Signal】 Adopt HDCVI 4th Generation Digital Signal, 120ft anti-interference no delay, applicable for vehicles within 65 feet vehicle(12-24V), give you a stable and clear monitor of road condition, be your reliable assistant.
☆【FHD1080P Capacitive Touch Button Monitor】 Ensure the sensitivity, stability, and reliability of the screen, FHD 1080 resolution, give you a unique visual exerience, and have strong anti-interference capabilities and strong adaptability to temperature ranges, prevent water get inside through Button.
☆【Side View Wireless Backup Camera & Recording】Built-in 32G SD card, can record thing on driving, Side View Camera fits the side better and cover the Blind Spots/Blind Zone. Support Single View Dual View or Quad View(CH1/CH2/CH4), you can switch to the mode you need.
☆【Night Vision & IP69 Waterproof】 Infrared Light and CCD Sensor accurately identify lawns, lakes, and stones even in the Dark. Closed with a Metal Gel, still work for you even at Rain /Snow/Fog, provide you all day intimate monitoring.
☆【Easy Installation & Wide Application】Wire camera to running light / tail lights/reverse lights to observe, Cigarette Lighter/ACC/Fuse/Radio can power monitor, Just connect power source and install antenna, you can start to use. Accommodate a large variety of vehicle as RV/Camper/Truck/5th Wheel Trailer/Bus/Van/Pickup.
☆ Please note that the system transmits the camera image to the monitor via a wireless 2.4GHz signal. There is no cable between the camera and the monitor, but the camera and the monitor need power cord to get power and work, which saves yourself the trouble of charging and provide convenient and safe monitoring for your travels.
