【Upgraded】 Emergency Weather Radio, Hand Crank, 4000mAH, Portable, Solar Charging, with AM/FM/NOAA, 3 LED Flashlights, Motion Sensor, Reading Lamp, SOS Alarm, Rechargeable (Green)
Price: $31.99
(as of Aug 18, 2024 15:45:35 UTC – Details)
1111
3-33-3
Learn More
K8K8
JALL rgb alarm clockJALL rgb alarm clock
Wooden Digital Alarm ClockWooden Digital Alarm Clock
22
5.5" LED Display Alarm Clock5.5" LED Display Alarm Clock
Analog Alarm ClockAnalog Alarm Clock
Digital Calendar Alarm ClockDigital Calendar Alarm Clock
【Upgraded Design】The upgraded hand crack raido has a 4000mAh bigger rechargeable batteries. The most powerful lighting functions include super-bright 3 mode flashlights, motor sensor & reading lamp.
【4 Charging Modes】The upgraded hand crack radio has 4 power sources when you need a boost of power or need to recharge the raido. The hand crank lever and solar panel are both capable of regenerating enough power to keep the radio, lights, and SOS alarm ready to go when you need it most. The rechargeable 4000mAh inside ensure you have power when not able to regenerate power. Also, you can recharge the hand crack radio(inside the rechargeable battery) with power cord.
【FM/AM & Weather Radio】A Life Saver radio! Get notified first for every weather alert in your area, such as hurricanes, tornadoes and severe storms, earn a critical time to prepare and save you and your family. Keep one in your emergency bag, you’ll be happy you did.
【3 Mode Super Flashligt and Motion Sensor&Reading Lamp】When you start exploring a strange place, taking the IPX3 waterproof radio with 3-flashlight is your better choice. The furthest lighting distance can be more than 10 meter because of the powerful batteries. In addition, with the motion sensors, the reading light will help you wake up at midnight and avoid waking up your family.
【SOS Alarm to Keep Your Safety】******Feel free to find us on amazon.com for any question.******When you are in emergency, press SOS button to activate the SOS Alarm searching for help. Also, with the flashing light, you are more likely to be found.
