Price: $32.31
(as of Apr 17, 2025 10:30:29 UTC – Details)
6000mAh Power Bank
The radio comes equipped with a power bank that will provide power to most of your USB devices. If you are in the outdoors or there is a power outage, the 6000mAh internal batteries will let you use the radio for a long time and also charge your mobile phone, allowing you to make emergency calls.
With Dual USB connection
The Power Bank comes with two USB connections allowing 2 devices to be charged at once!
Multiple Power Sources
With 4 ways to power this Emergency Radio keep your devices fully charge when you need it the most!
Specifications Frequency: FM: 87 -108 MHz Battery: 3x 2000mAh Li-ion 3.7V Power Consumption: 15W (Max) Charging Time (USB): 4 – 6 hours USB Output: DC 5V±0.5V, 2.4A
Compact & Portable!
With its sleek design, our portable light is easy to store! Weighing just under 2lbs this lightweight lantern makes it easy to carry & hang. Big enough to provide all the lights you need, but small enough to fit anywhere!
Click, Set & Go!
Easy to use settings with 4 brightness modes. Perfect for any type of black outs or if you just need a extra hand. Our stand is sturdy & removable making it easy to set and place.
Prepare & Forget!
You never know when you’ll need a extra pair of lights. Prepare ahead of time and store this flash light at home or in the car. Perfect for lighting up the way when you need it the most!
Not just a emergency light!
With our warm white mode this can be used as a reading light as well! Have the freedom to adjust the light for your best reading experience!
A must have tool for your survival kits!
FosPower’s emergency radio provides you with multiple tools to help you out in an emergency. The radio has FM radio stations, NOAA weather channels, a dimmable reading light, an SOS alarm, a power bank, and 4 power charging options.
[4 POWER SOURCES WHENEVER YOU NEED IT] Use the emergency weather radio’s 4 power sources when you need a boost of power or need to recharge the radio. The radio’s crank lever and solar panel are both capable of regenerating enough power to keep the radio, lights, and SOS alarm ready to go when you need them most. The USB-C cable provides you the most efficient way to recharge your radio. You are able to power the radio with the internal batteries or AAA batteries.
[SOS ALARM AND DIMMABLE LIGHTS] In an emergency situation, the SOS function will allow you to call for help by making a loud siren sound. The lamp has 4 brightness levels and two lighting modes. Warm light is great for reading, and cold light is capable of lighting your way to a safe place.
[NOAA EMERGENCY WEATHER BROADCAST ACCESS] The radio will dependably receive NOAA channels for local weather information and emergency hazard alerts. The FM function provides full access to all FM radio broadcasts.
[LIMITED LIFETIME WARRANTY] Join millions of satisfied customers with our limited lifetime warranty, backed by our experienced and dedicated USA based customer service.
