Price: $37.78
(as of Aug 24, 2024 19:45:14 UTC – Details)
Solar Crank Emergency Radio
FosPower’s emergency radio provides you with multiple tools to help you out in an emergency. The radio has AM/FM radio stations, NOAA weather channels, a LED flashlight, a LED reading light, an SOS alarm, a power bank, and 3 power charging options.
4000mAh Power Bank
The radio comes equipped with a power bank that will provide power to most of your USB devices. If you are in the outdoors or there is a power outage, the 4000mAh internal batteries will let you use the radio for a long time and also charge your mobile phone, allowing you to make emergency calls.
Package Includes
1x Solar Crank Radio
1x Charging Cable
1x Carabiner
1x User Manual
Emergency Radio and Light Sources
FosPower’s emergency weather radio will give you dependable access to emergency NOAA weather broadcasts and AM/FM radio stations. The 6 LED reading light is bright enough for outdoor activities, and the 1 Watt flashlight with far and dipped settings is capable of lighting your way in an emergency situation.
Multiple Power Sources
The solar crank emergency radio’s micro-USB cable, solar panel, and crank lever provide full battery power. The solar panel and crank are regenerative energy, ensuring you have power whenever you need it.
Specifications
Frequency FM: 87 -108 MHz / AM: 520 – 1710 KHz WB 162.40 – 162.55 MHz Battery 2x 2000mAh / 3.7V Li-ion Working Voltage 2.7V – 4.2V Power Consumption 10W (Max) Charging Time (USB) 5 – 6 hours USB Output DV 5V/1A LED Flashlight 135 lm (Max) Radio Listening > 33 hours (Medium Volume) Reading Lamp > 20 hours Flashlight Far or Dipped Beam: > 16 hours Far + Dipped Beams > 10 hours IP Rating IPX3 Item Weight 0.84 lb / 380 g Item Dimensions 6.23 x 2.48 x 3.19 in / 160 x 63 x 81 mm Manufacturer Part Number FOSPWB-2402
POWER BANK
4000 mAh 2000 mAh 4000 mAh
SOS SIREN
LIGHT SOURCES
LED Flashlight and Reading Lamp LED Flashlight and Reading Lamp LED Flashlight
RADIO BROADCAST ACCESS
NOAA, AM/FM stations NOAA, AM/FM stations NOAA, AM/FM stations
HAND CRANK
SOLAR CHARGE
BATTERY BACK UP
None x3 AAA Batteries (Not Included) x3 AAA Batteries (Not Included)
RECHARGEABLE BY
Micro USB Micro USB Micro USB
CONTROL PANEL
Tuner Dial Tuner Dial Digital LCD Screen
[3 POWER SOURCES WHENEVER YOU NEED IT] Use the emergency weather radio’s 3 power sources when you need a boost of power or need to recharge the radio. The radio’s crank lever and solar panel are both capable of regenerating enough power to keep the radio, lights, and SOS alarm ready to go when you need them most. The micro-USB cable provides you the most efficient way to recharge your radio.
[SOS ALARM AND 2 LIGHT SOURCES] In an emergency situation, the SOS function will allow you to call for help by making a loud siren sound and a flashing light, and the flashlight and reading light are capable of lighting your way to a safe place. Turning the sensor switch to the AUTO position allows the motion sensor to automatically turn on/off the reading light to save energy.
[NOAA EMERGENCY WEATHER BROADCAST ACCESS] The radio will dependably receive NOAA channels for local weather information and emergency hazard alerts. The AM/FM function provides full access to all AM and FM radio broadcasts.
[LIMITED LIFETIME WARRANTY] Join millions of satisfied customers with our limited lifetime warranty, backed by our experienced and dedicated USA based customer service.
