Price: $17.91
(as of Apr 12, 2025 10:45:22 UTC – Details)
Enhance your Emergency Preparedness with FosPower’s Solar Crank Emergency Weather Radio The weather radio provides you with tools to use in emergency and non-emergency environments. The radio comes integrated with a 1W LED flashlight with zoom, an SOS alarm, 2000mAh power bank, 2 LED lights, radio broadcasts access, and 3 power options to provide emergency power. Integrated Power Bank Keeps Your Devices Powered in an Emergency A 2000mAh power bank provides enough emergency power to any mobile device in emergency situations. Works with most USB powered devices. 3 Power Sources The solar crank emergency radio’s AAA batteries, a solar panel, and a crank lever provide full battery power. The solar panel and crank are regenerative, ensuring you have power whenever you need it. —- Emergency Sleeping Bag The FosPower emergency sleeping bag is a useful tool to have in an emergency. Whenever you are in a hazardous situation and need help staying warm, the sleeping bag will retain up to 90% of your body heat, keeping you dry and clean as you wait for help to come. It is an essential item to have in your bug-out bag. Multiple Uses The FosPower bivy sack can also be used as an emergency blanket or to help build a survival shelter. The large, bright orange surface is easy to spot and can send a visual help signal. The bivy sack also comes with an emergency keychain whistle that you can blow to serve as an SOS. This is a great addition to your survival kit while you are hiking, camping, or boating. Durable and Lightweight The sleeping bag is made with 26μm thick PE material, which is very durable and able to be used multiple times. The material is waterproof, windproof, tear resistant, and puncture resistant. This bivy sack is also extremely compact and lightweight, weighing in at only 3.7 ounces / 106 g.
[3 POWER SOURCES POWER WHEN YOU NEED IT] Use the emergency weather radio’s 3 power sources when you need a boost of power or need to recharge the radio. The radio’s crank lever and solar panel are both capable of regenerating enough power to keep the radio, lights, and SOS alarm ready to go when you need it most. AAA Batteries ensure you have power when not able to regenerate power.
[WATERPROOF THERMAL SLEEPING BAG] Whether you’re packing to go camping or preparing a survival kit for your family, the FosPower emergency sleeping bag is one item you cannot miss. The sleeping bag will retain up to 90% of body heat to keep you warm in cold weather. The waterproof and windproof material and reinforced tape seam make the sleeping bag resistant to rain, snow, and wind.
[EMERGENCY SURVIVAL KIT] The FosPower sleeping bag has multiple uses in emergencies. You are able to use this bag as an emergency sleeping bag, bivy sack, blanket, survival shelter, ground shelter, shade, rain poncho, distress signal, and many more. This stuff bag comes with a survival whistle that will allow you to make a loud SOS audio signal.
[COMPACT AND LIGHTWEIGHT] The dimension of the sleeping bag is 36” x 84” (91×213 cm), large enough for any size body. After using it, simply fold and insert it into the waterproof stuff sack, which is about the same size as your smartphone. The ultra-light sleeping bag only weighs 3.6 ounces, giving you peace of mind with no added bulk.
