FORTECLEAR 5000mAh Hand Crank Solar Emergency Radio, 3W LED Flashlight/Reading Lamp Weather Radio, NOAA/AM/FM Portable Radio Indoor and Outdoor, SOS Alarm and Phone Charge, Survival Gear for Hurricane
Price: $24.98
(as of – Details)
5000mAh NOAA Radio with Battery Backup – With the built-in 5000mAh batteries, this AM/FM/NOAA Radio can keep you up-to-date on weather conditions, provide a reassuring LED flashlight and reading light, activate SOS alarms, or even double as a phone charger or power bank for other devices. This rechargeable NOAA Weather Radio can deliver up to 20 hours of radio time or up to 8 hours of flashlight use on a single charge
Built-In LED Flashlight & Reading Light – You can get illumination from the LED flashlight or the reading light. The 3W LED flashlight lets you choose from 3 brightness settings to suit your needs. The 6 LED reading lamp allows up to 40 hours of reading time. A separate SOS button lets you activate the SOS alarm siren and flashing Morse code beacon if you need help
3 Different Power Sources – This portable hand crank solar emergency radio can be powered via Type-C charging, the hand crank or solar panel. Its Type-C charging port allows you to quickly charge the radio. Its solar panel makes it a great option if you’re hiking or camping out under the sun. One minute of manual cranking can deliver up to 50 minutes of light or 6 minutes of radio
A Must-have Emergency Kit – This 380g portable radio can offer the up-to-date news and weather conditions, power, or illumination that you will need yet is compact enough to fit in a backpack or emergency kit. It is a must-have emergency gear that is great for using at home, on the road, or in the great outdoors. A USB Type-C charging cable and lanyard are included. We offer friendly customer service
