Price: $36.99
(as of Mar 25, 2025 11:00:35 UTC – Details)
FORTECLEAR puts customers’ needs and good customer experiences at the center of attention since its establishment, and we are happy to communicate with consumers to improve our products and service. We have delicately designed and independently developed each audio device. We are committed to creating full-featured products of excellent performance, unique appearance, and strong practicability.
Speaker & Radio
5000mAh NOAA Radio with Battery Backup – With the built-in 5000mAh batteries, this AM/FM/NOAA Radio can keep you up-to-date on weather conditions, provide a reassuring LED flashlight and reading light, activate SOS alarms, or even double as a phone charger or power bank for other devices. This rechargeable NOAA Weather Radio can deliver up to 20 hours of radio time or up to 8 hours of flashlight use on a single charge
Built-In LED Flashlight & Reading Light – You can get illumination from the LED flashlight or the reading light. The 3W LED flashlight lets you choose from 3 brightness settings to suit your needs. The 6 LED reading lamp allows up to 40 hours of reading time. A separate SOS button lets you activate the SOS alarm siren and flashing Morse code beacon if you need help
3 Different Power Sources – This portable hand crank solar emergency radio can be powered via Type-C charging, the hand crank or solar panel. Its Type-C charging port allows you to quickly charge the radio. Its solar panel makes it a great option if youβre hiking or camping out under the sun. One minute of manual cranking can deliver up to 50 minutes of light or 6 minutes of radio
A Must-have Emergency Kit – This 380g portable radio can offer the up-to-date news and weather conditions, power, or illumination that you will need yet is compact enough to fit in a backpack or emergency kit. It is a must-have emergency gear that is great for using at home, on the road, or in the great outdoors. A USB Type-C charging cable and lanyard are included. We offer friendly customer service
