Fookoo 1080P 10″ Wireless Backup Camera System, 10″ Dual/Quad Split Monitor with Recording, IP69 Waterproof Rear/Front View Cameras, Parking Lines for RV/Truck/Trailer/Van(DW102)
Price: $279.99 - $159.00
(as of Mar 25, 2025 20:15:26 UTC – Details)
Fookoo has been established for over 10 years. Fookoo is a thriving technology brand specializing in backup camera system, dash camera, and solar backup camera.
【Split Screen & Loop Recording】For the dual/quad split screen monitor, you can add more cameras if you need, then you can view images of different cameras simultaneously. The system can record and save what is displayed on the screen. With loop recording, when the SD card is full, the system will automatically overwrite the previous videos. (It contains a 32GB SD card.)
【Advanced Digital Wireless Signal】The system with stable digital signal works flawlessly within 128ft range in open area, enough for any large vehicles. Even at the high speed of 102mph, the monitor will display the surroundings in real time, making your driving more convenient. There is no interference, flicker, blurring or delay.
【IP69 Waterproof Cameras】The IP69 waterproof camera works perfectly in any extreme weather. With 18 infrared lights, the camera can provide HD night vision for you. The lens of the camera can be adjusted up and down, allowing you to view from different angles. The hard metal housing makes the camera serve longer for you.(It can work with Furrion pre-wired RV, please ask us for the bracket adapter.)
【Easy to install & After-Sale Service】Voltage ranging from DC 12-24V power supply is suitable for a wide variety of large vehicles such as RV/Camper/5th Wheel Trailer/Bus/Van/Pickup/Farm Machinery. If you find anything defective or need help, please reach us. We are online 24 hours and we offer a 24-month replacement support and lifetime after-sale service!
【Please Note】Wireless means that the system transmits the footage captured by the camera to the screen through a wireless signal instead of using a cable. But the cameras and monitor still need to be connected to a power source via power cord to get power to work properly. There is no cable between the cameras and the monitor in a wireless system than in a wired system, so you don’t need to run cables on your vehicle, which is more convenient.
