FFpower P2001 Solar Generator, 2000Wh Power Station with LiFePO4 Batteries, 6 2000W AC Outlets, UPS Backup, Bi-directional Portable Power Station for Home Power Outage, Outdoor Camping RV
Price: $999.99
(as of Jan 21, 2025 15:15:23 UTC – Details)
Wattage :
2000 watts
Discharge and Charge Simultaneously: FFpower is designed to charge and discharge at the same time a,k.a pass-through charging. This means you can have a solar panel or some other power source recharging the FFpower P2001 while another device (cell phone, computer, etc) is taking power from this power station.
Long lasting Lifespan: FFpower is adopt lithium iron phosphate(LiFePo4) as chemistry battery. It has the characteristics of fireproof and explosion-proof, and rated to 3500 life cycles to 70% capacity, the battery lifespan is 7 times than the standard lithium-iron(NCM) batteries
Save your time: P2001 uses a 2000W bi-directional inverter, you will get a fast charging speed while using AC charging cable.The capacity from 0% to 100% can be completed within 2 hours.
Get power energy from Sun: FFpower P2001 is compatible with any solar panels (12-48V, MAX 500W) on the market. We recommend you to use a 200Watt, 24 Voltage solar panel, as you know the solar panels are affected by many factors such as the light intensity and the panel’s angle put on the ground. Please try use the solar panel under the full sunlight to charging, and make sure there is no shadow cast on the panel.
Protect your computer data: P2001 power station equipped with UPS function, once a power outage occurs, P2001 will goes into effect immediately to be able to power the computers and devices, a standby UPS resorts to battery backup power in the event of common power problems such as a blackout, voltage sag, or voltage surge.
