Price: $89.99
(as of Apr 07, 2025 07:00:41 UTC – Details)
EWAY Wireless Portable Hitch Camera
A More Easily and Safety Solution to Hitch Your Trailer
Simple use system is ready to use in under one minute. Setup includes just two steps; mounting the camera magnetically to any metal surface and connecting it to a mobile device via WiFi Hot Spot. Portable camera sends images to your iOS/Android device for easier backing up, hitching up, or rock crawling.
Battery-powred Truly Wireless Vehicle Backup Camera for Car/Truck/Trailer
Wireless design – camera becomes a Wi-Fi hot spot when it is turned on. When the camera is turned on, it creates its own Wi-Fi hot spot that works anywhere, regardless of cellular service and without the need for radio frequencies.
8 Infrared LED Lights – Excellent Performance at Day & Night
Get clear real-time video even at very dark night, perfect for when you need a better view for rock crawling, parking, monitoring, or hitching up to your trailer.
With 4 Strong Magnets at Bottom, Install the Way You Like
Magnetic base allows for simple setup and repositioning to suit your needs. 4 rare earth magnets at bottom let you mount the camera on your vehicle’s tailgate or on any other metal spot on the body. Each powerful magnet has 15 lbs of pull, so the camera is mounted securely.
Portable Camera with Magnetic Base
1 Mount Flexible 2 No Delay on Road 3 Use Phone as Monitor 4 Stable WiFi Signal
1 150° Wide Viewing Angle 2 Durable Performance 3 IP68 Waterproof 4 Excellent at Night
EWAY Wireless Backup Camera For Cars Trailers RVs Trucks
Installation
Magnetic Base
Magnetic Base/Suction Cup Base
Surface Mounting
Power Supply
Rechargeable Battery
5-24V DC
Transmission Range
100ft(No obstacles)
100ft(No obstacles)
100ft(No obstacles)
100ft(No obstacles)
100ft(No obstacles)
Removable Guideline
Video Recording
x
Front / Rear View
Monitor Size
Phone Monitor
5″
4.3″
x
5″
Available for Android and iOS
x
x
x
➤【Rechargeable Battery】WiFi portable RV backup camera powered by rechargeable lithium ion built-in battery. The battery is easily charged with the USB power cable. 📌NOTE: This system is not compatible with Google Pixel phones.
➤【Strong Waterproof & IR Superior Night Vision】Safe and patented, US Patent number 10,894,515 RV camera. Rated IP68, can fully protected against dust and can withstand being submerged in water up to 1.5 meters (5 feet) for 30 minutes. 9 automatic Infrared night vision lights = 30ft. of vision in the darkest night, which doesn’t need any ambient light.
➤【Wide Transmission Range】The wireless digital system boasts a 100ft digital wireless range(No obstacles), which is guaranteed to work even at highway speeds. Perfect for Truck, Camper, RV, Trailers, Travel Trailers, Fifth Wheels ect (Recommend for used at vehicles length of less than 35ft).
➤【Use Your Phone/Tablet Monitor】WiFi Magnetic Hitch Backup Camera comes with the ‘RV Camera’ phone app. Use your iPhone iPad Android cellphone smartphone tablet to connect its Wi-Fi, you can see what’s happening behind your vehicle on the app. No monitor on dash any more.
