ENGEL 17 Quart Portable top-Opening 12/24V DC – 110V/120V AC Fridge-Freezer
Price: $1,049.99
(as of Apr 04, 2025 22:15:16 UTC – Details)
When power and space allow, consider an Engel MT-series fridge/freezer. Every Engel fridge/freezer is capable of keeping contents fresh – or frozen – wherever you roam. Freeze food to last you on long trips, or set the temperature control to keep fresh food and drinks chilled. All Engel fridge/freezers feature the Engel Swing Motor Compressor. Highly efficient, it typically draws around 1 to 2 Amps per hour (check the specs for each individual model), about 40% less than a traditional compressor Engel fridge/freezers run on battery power (12V/24V DC) or 110V/120V AC so whether you?re on the road, on the water, or safe at home, you can use your Engel to make life a little easier.
Variable Temperature Control
Incline Operation up to 30° Off Level
Automatic Voltage Selection Between AC and DC Power
Highly Efficient Engel Swing Motor – Low Amp Draws (Even At Start-Up)
Solar Compatible
Vibration Resistant for Extreme Conditions
Will Operate approximately 80 Degrees (F) From Ambient Temperature
AC & DC Cord 12V/24V Plug
