Price: $35.90
(as of Apr 10, 2025 20:45:18 UTC – Details)
【 BIGEST CAPACITY BATTERY】:The 4000mAh large capacity battery of emergency radio cellphone charger is twice or even four times that of other weather emergency radio, which is the bigest capacity in the weather radio’s market. You will never image the battery capacity of the crank flashlight radio is large than large cell phone. Better solve the problem of crank solar radio battery life and charging mobile phone in case of emergency suitation.
【LIGHTING “3+2″】:Whether it’s three flashlight modes or two reading lights mode and the brightness of the crank radio is the only one in our emergency portable radio. “3” is the flashlight made by high lumen LEDs provide dipped beam, high beam and dipped&high beam. totally can be used as a flashlight. “2” is reading lamp made by 6 LEDs provide always on and motion sensor reading. Satisfy your needs and light up your night.
【4 POWER SOURCES POWER】: Hazard weather always lead to power outages and you would like to have this portable emergency radio. Hand crank and solar power these two power sources can power the weather emergency radio when you need in emergency. USB fast charging is the main power way in daily use. Rechargeable battery can be replaced and you can find it in any stores and supermarket. Power up anytime and anywhere.
【WHAT OUR CONCERNS】: It took us three years of market research and customer demands to get this crank weather radio. You will find that this solar crank radio emergency has been with you through every bad weather, also a good partner of camping and other outdoor activities. We provide good quality product, our support and 3 years warranty to you, you give us your voice. Our world customer service is waiting for you 24/7 anytime.
