Emergency Solar Hand Crank Radio,6000mAh Hand Crank FM/NOAA Weather Radio 4 Ways Powered,Portable Battery Operated Radio with LED Camping Lantern,Phone Charger,SOS for Home,Camping,Survival
Price: $20.99
(as of Mar 29, 2025 07:45:20 UTC – Details)
[FM/NOAA Weather Radio]This emergency weather radio receives the latest emergency weather forecasts and emergency news broadcasts from 7 NOAA, allowing you to take precautions and stay safe before severe weather arrives. You can also receive local broadcasts on the FM band and provide you the latest news and interesting program. The extensible antenna makes it a emergency hand crank radio better reception effect.The hand crank radio has a carry handle design for easy portability.
[4 Power Sources-Long Runtime]This solar hand crank radio is ready and save your life in emergency.Built-in 6000 rechargeable battery, the weather radio is easily powered by solar/hand crank and Type-C cable(included).It is also equipped with battery compartment at the bottom of the solar radio(3AAA batteries, not included). No more power failure concerns in any situation.In addition, a power indicator is designed to remind you to charge in time so that have enough power in case of emergency.
[Adjustable Reading Lamp]Unlike the emergency weather radios on the market, the upgraded hand crank radio has more innovative lighting methods.When the reading lamp is turned off, it is in cold light mode, and when it is turned on, it is in warm light mode.Both modes have 4 levels of adjustable brightness.The lowest brightness can emit soft and not harsh light, and the highest brightness can illuminate the whole tent. The LED camping lantern is ideal light source for reading or studying at night.
[SOS Alarm&After-sale Protection]If you encounter any accidents or bad weather at home or outdoors, you can use the emergency radio’s SOS alert (about 80 dB) to call for help in case of an emergency. The loud sos siren is more likely to attract the attention of others.We back our emergency weather radio with 12-months Warranty! Our customer service are here for you 24/7 for anything you need and help you out.You don’t want to miss this solar hand crank radio and just pick it now!
