Emergency Solar Hand Crank Radio with 5 LED Flashlight for Survival, NOAA/AM/FM Portable Weather Alert Radio with Reading Lamp,Battery Operated,Portable Power Bank for Phone Charging,SOS Mode for Help
Price: $35.99 - $29.99
(as of – Details)
3-WAY POWER SOURCES: ๐—ก๐—ข๐—”๐—” ๐—ฒ๐—บ๐—ฒ๐—ฟ๐—ด๐—ฒ๐—ป๐—ฐ๐˜† ๐˜„๐—ฒ๐—ฎ๐˜๐—ต๐—ฒ๐—ฟ ๐—ฟ๐—ฎ๐—ฑ๐—ถ๐—ผ with multiple charging options for hazardous weather in power outages, including micro USB adapter charging, hand crank charging, and solar panel charging. The 110~220V AC wall power outlet is the fastest way to get full recharge for daily use, highly recommended. Hand crank and solar charging can keep the ๐˜€๐—ผ๐—น๐—ฎ๐—ฟ ๐—ต๐—ฎ๐—ป๐—ฑ ๐—ฐ๐—ฟ๐—ฎ๐—ป๐—ธ ๐—ฟ๐—ฎ๐—ฑ๐—ถ๐—ผ power on, which can provide instant, latest messages about weather alerts.
5 MODES FLASHLIGHT & SOS ALARM: This ๐—ฝ๐—ผ๐—ฟ๐˜๐—ฎ๐—ฏ๐—น๐—ฒ ๐—น๐—ถ๐—ด๐—ต๐˜๐˜„๐—ฒ๐—ถ๐—ด๐—ต๐˜ ๐—”๐—  ๐—™๐—  ๐—ฝ๐—ผ๐—ฟ๐˜๐—ฎ๐—ฏ๐—น๐—ฒ ๐—ฟ๐—ฎ๐—ฑ๐—ถ๐—ผ has an SOS alarm with flashlights for emergencies. The flashlight with different brightness in different modes will give you a wide view outdoors at night or indoors when the power goes out. Long press the SOS BUTTON for 3S while you are in an emergency, ๐—น๐—ผ๐˜‚๐—ฑ ๐—ฆ๐—ข๐—ฆ ๐—ฎ๐—น๐—ฎ๐—ฟ๐—บ is very easy to get the attention of others and get help.
3000MAH PHONE CHARGER: Charge Your Phone powered by the ๐—ก๐—ข๐—”๐—” ๐˜„๐—ฒ๐—ฎ๐˜๐—ต๐—ฒ๐—ฟ ๐—ฎ๐—น๐—ฒ๐—ฟ๐˜ ๐—ฟ๐—ฎ๐—ฑ๐—ถ๐—ผo with the 3000mAh rechargeable lithium polymer battery, connect your phone charging cable with the USB output port by opening the covered rubber flap, which keeps your phone charged even during a power outage during an emergency, use it as a normal power bank, and the supplied charging cable is only for charging Micro USB device.
LED READING LAMP: A ๐—บ๐˜‚๐˜€๐˜-๐—ต๐—ฎ๐˜ƒ๐—ฒ ๐—ณ๐—ผ๐—ฟ ๐—ฐ๐—ฎ๐—บ๐—ฝ๐—ถ๐—ป๐—ด ๐˜€๐—ฎ๐—ณ๐—ฒ๐˜๐˜† and ๐˜€๐˜‚๐—ฟ๐˜ƒ๐—ถ๐˜ƒ๐—ฎ๐—น ๐˜€๐˜‚๐—ฝ๐—ฝ๐—น๐—ถ๐—ฒ๐˜€ with a reading lamp. Flip up the solar panel to become a ๐—ฟ๐—ฒ๐—ฎ๐—ฑ๐—ถ๐—ป๐—ด ๐—น๐—ฎ๐—บ๐—ฝ with flashlights to illuminate your way to the place you want to go at night, which will help you walk in places without lights, light up in full darkness to keep you safe, and keep you and your families out of the dark in an emergency.
HIGH QUALITY & CUSTOMER TECHNICAL SUPPORT: This waterproof IPX4 ๐—ฝ๐—ผ๐—ฟ๐˜๐—ฎ๐—ฏ๐—น๐—ฒ ๐—ฒ๐—บ๐—ฒ๐—ฟ๐—ด๐—ฒ๐—ป๐—ฐ๐˜† ๐—ฟ๐—ฎ๐—ฑ๐—ถ๐—ผ ๐˜„๐—ถ๐˜๐—ต ๐—ณ๐—น๐—ฎ๐˜€๐—ต๐—น๐—ถ๐—ด๐—ต๐˜๐˜€ can resist water, dirt, and shock, suitable for extreme conditions both indoors and outdoors usage. The ๐—ณ๐—น๐—ฎ๐˜€๐—ต๐—น๐—ถ๐—ด๐—ต๐˜ ๐—ฟ๐—ฎ๐—ฑ๐—ถ๐—ผ has 18 month’s warranty and 30 days of free return&refund service, and 24/7 online customer service, if you have any questions, please don’t hesitate to contact us, we will respond as soon as possible.
