Price: $49.99 - $39.99
(as of Mar 15, 2025 18:15:18 UTC – Details)
ROCAM AM/FM/Noaa Weather Radio
No more power outages, no more losing contact with the outside . Emergency radio helps you win rescue time and ensure our safety.
5 Power Sources and Rechargeable Battery – This portable radios supports 5 power modes to keep the generator on power, you can use the Micro USB to recharge the device, or use the smooth hand crank to supply, the sturdy solar charge could be an optional method, and this solar radio has upgraded to replaceable battery which you can charge your smart devices, tablets or phones anytime. You can even install 3 AAA batteries when you are not able to regenerate power.
NOAA Certified Emergency Weather Alert Access – This upgraded emergency radio will captures a superior and stable signal reception with the telescoping antenna, upgraded DSP chips and high-quality built in speaker. Enable the NOAA Alert function and once a weather alert is received, there will be a loud warning sirens come out and the ALERT icon on the large LCD display will flash, to alert you the hazard weathers in your area such as tornadoes, hurricanes, and sever storms.
2 Brightness Light Sources & SOS Siren to Keep You Safe – The emergency radio comes with a super bright 2 brightness level 3W reading lamp and flash light for any dark place you are in and could substitute a regular flashlight in a pinch. It also features an SOS mode so if you get separated from a group when hiking or camping you can emit a loud siren and flashing red signal light so your partner can hear and find you.
Easy to Carry & Waterproof – The size for this weather radio is compact and lightweight, it is fitted with a strap and carabiners for attaching it to your belt or hanging it from a rope.and it is made of strong ABS material which is IPX3 water resistance. Very convenient to carry for camping, traveling, fishing or any other outdoor activities. What’s more, we provide customers with 12 Months Replacement Warranty and 7/24 after-sale service. A great life saver for you and your caring people.
