Emergency-Radio,Puiuisoul 4000mAh Weather Radios with Hand Crank & Solar Charging,3 Gear LED Flashlight,SOS Alarm, Portable Power Bank,AM/FM/NOAA,Motion Sensor Reading Lamp
Price: $39.99
(as of Mar 24, 2025 03:45:18 UTC – Details)
radio
radio
Puiuisoul Emergency radios
Puiuisoul – provide a more portable and versatile emergency radio to protect you and your family.
品牌故事1
品牌故事1
品牌故事2
品牌故事2
Emergency radios keep you safe
[WE CARE YOU AND YOU FAMILY]- Portable NOAA stations at a crystal-clear sound weather radio with flashlight for lighting road in dark and SOS alarm ready to Nature is unpredictable, but you can be prepared and ready in the face of her fury. In the past years, our emergency radio has helped thousands of USA Civilians to live through the hurricane, tornadoes and snowstorm season.
[IT’S THE PERFECT CANDIDATE FOR LIFE]- The IPX3 waterproof radio with flashlight is a great choice if you’re an outdoor enthusiast or need to walk in unlit areas. In case of emergency, you can press the “SOS” button and the emergency radio will sound an alarm so that rescuers can find it in time. Perfect for camping, hiking, kayaking and other outdoor activities.
[4000 mAh LARGE CAPACITY]- Compared with the 1000 mAh and 2000 mAh emergency radios on the market, the solar radio is upgraded to 4000 mAh replaceable battery. Hand cranking, solar charging, USB charging method. USB charging is the main power source for daily use, but you can use hand cranking and solar power to regenerate enough power in dark or no power emergencies. Charge your phone and other electronics with the 4000mAh emergency power supply. Always safe.
[BE THE MOST RESPONSIBLE SELLER]- Emergency radios use automatic gain control (AGC) technology to change their gain based on the level of the input signal. As a result, it’s easier to capture the signal, whether it’s NOAA or FM/AM. To ensure a better experience, if you are not satisfied with this hand crank radio, you can contact us and our customer service is at your service 24 hours a day! We will always be responsible for the products we sell! The product has an 18-month warranty!
