Price: $79.99
(as of Mar 06, 2025 14:45:15 UTC – Details)
【LARGE DIGITAL LCD SCREEN】: To make the user to know the accurate channel more clearly and choose the correct station, we design a 1.4*1.7 inches digital LCD screen in this weather alert radio. All information of the AM FM band, frequency, battery capacity, voulme show on the LCD screen. You can know more about the state of crank radio. This emergency weather radio also has the auto scan and the backlight setting, allows you to operated easily and use even at night.
【ALL EMERGENCY FUNCTIONS REQUIRED IN ONE】:Both AAA batteries and 2000 rechargeable battery two types of pwer source can be used as power bank in this solar radio, which can charge your USB devices. SOS alarm and the 1W bright flashlight is very useful in outdoor emergency situation. This hand crank radio is also support the standard earphone(earphone not included). In consideration of its practicability, we mix the bottle opener in this solar crank radio for camping or using in home.
【4 POWER SOURCES WHEN YOU NEED IT】: Hazard weather always lead to power outages and you would like to have this weather emergency radio. Hand crank and solar power these two power sources can power the weather emergency radio when you need in emergency. USB fast charging is the main power way in daily use. 3 AAA batteries can be powered and you can find it in any stores and supermarket. Power up anytime and anywhere.
【COST-EFFECTIVE WEATHER RADIO】: You can not imagine such a 6.2*1.85*3.2 inches digital weather alert radio which included the a large digital LCD screen, weather alert, flashlight, SOS alarm, radio and 4 power sources. Keep one crank solar radio can replace all these things. You will find that this weather noaa radio has been with you through every bad weather, also a good partner of camping and other outdoor activities. Our world customer service is waiting for you 24/7 anytime.
