Emergency Radio Topsics 8000mAh Solar Hand Crank Weather Radio 4 Ways Powered AM/FM/SW/NOAA Weather Alert Portable Radio with Flashlight, Reading Lamp, Cellphone Charger and SOS Alarm
Price: $33.99
(as of – Details)
emergency crank radioemergency crank radio
Topsics 8000mAh Multifunctional Emergency Radio
8000mAh Large Capacity Battery –The Radio built-in 8000mAh battery, can be used as a power bank to charge your phone in case of emergency.
AM FM WB NOAA Weather Radio with Weather Alert — The emergency crank radio tunes in to all of the NOAA weather stations and AM/FM radio. With the weather alert feature, Radio sounds an alarm to indicate severe weather risks in your area.
4 Charging Ways——Type-C fast charging, solar panel Charging, hand cranking and a built-in rechargeable battery, making it the ideal emergency tool in case of a power outage.
3 Modes of Flashlight with SOS Alarm ——This weather radio with 3W flashlights, provide different brightness in different modes,Press the sos button,the SOS alarm clocks provide a loud alarm no matter where you are.
Reading Lamp and Helpful Mini Compass——Gives you help when you are in the wilderness to discern your direction, the 2.5W reading lamp is handy during dark.
3.5mm Earphone Jack—— Radio plus a 3.5mm headphone jack, allows you to enjoy radio shows without disturbing others.
IPX3 Waterproof——With the IPX3 waterproof, small raindrops splashing on this wind up radio will not make damage (But please do not soak in water).
electricty free power sourceselectricty free power sources
Emergency-RadioEmergency-Radio
weather alertsweather alerts
reading lightreading light
flashlightflashlight
Automatic NOAA Weather Alert
Receive all the 7 NOAA weather stations Automaticlly .No need to listen to the radio all the time, you will hear 1-minute alarm before you receive the NOAA warn information!
2.5W Reading Lamp
2.5W 𝗿𝗲𝗮𝗱𝗶𝗻𝗴 𝗹𝗮𝗺𝗽 are available,Also, a reading lamp will greatly help you get up in the mid-night to avoid waking your family
3 Model Flishlight
This weather radio with 3W flashlight, The flashlight provides enough output to keep you and your loved ones out of the dark in an emergency situation.
Dimensions 174.9 X 79.6 X 97.6 mm Weight 510g Maximum power 19W Working voltage 2.4V~4.2V Battery capacity 8000mAh (two 3.7V/4000mAh batteries) Battery life more than 3 years (average daily use of 3 hours); about 500 cycles of use Operating temperature range -10℃ – +60℃ Waterproof IPX3 Quiescent current ≤0.3mA AM/FM Frequency FM: 87~108MHz, AM: 522~1710KHz WB Frequency Band 1: 162.400, Band 2: 162.425, Band 3: 162.450, Band 4: 162.475, Band 5: 162.500, Band 6: 162.525, Band 7: 162.550 Mhz Weather Alert Band 1: 162.400, Band 2: 162.425, Band 3: 162.450, Band 4: 162.475, Band 5: 162.500, Band 6: 162.525, Band 7: 162.550 Mhz Working time1 ≥72 hours (Moderate volume) Working time 2 ≥24 hours (maximum volume)
LED Flashlight
2 LED(3 modes) 2 LED(3 modes) 1 LED 1 LED 2 LED(3 modes)
capacity
8000mAh 8000mAh 2000mAh 2000mAh 4000mAh
Bluetooth
TF Card
SOS Alarm
Size
21.8 x 13.7 x 9.7 cm 21.8 x 13.7 x 9.7 cm 10.8 x 6.4 x 5.3 cm 16.7 x 9.3 x 6.6 cm 19.8 x 9.4 x 5.5 cm
Input Port
Type-C fast charge Type-C fast charge USB USB USB
Output Port
Earphone jack & USB Earphone jack & USB Earphone jack & USB USB USB
NOAA Weather Radio & SOS Alarm – Portable AM/ FM/ NOAA weather radio can be used not only for listening to radio and weather, but also SOS alarm, besides, This multi-function radio also comes with weather aleart , turn the knob to Weather aleart, to forecast severe weather in advance. Frequency: FM: 87~108MHz, AM: 522~1710KHz
3 Model Flishlight and Reading Light – This weather radio with 3W flashlights and 2.5W reading lamp are handy during emergency power cuts to see any signal in the dark. This emergency weather radio can be a great tool during dangerous disasters like tornadoes and hurricanes. And plus a 3.5mm headphone jack, allows you to enjoy radio shows without disturbing others.
Hand crank radio with 4 charging methods – This crank solar radio supports Type-C cable (5V 2A)fast charging, hand crank Charging, solar panel Charging and replaceable battery. The weather radio for camping with multiple power backup options are the perfect choice for camping, survival, adventure
Outdoor Camping Radio with Compass – Size: 17.5*8*9.6cm / 6.8*3.1*3.7inch, Weight: 520g/ 1.1lbs Small and easy to carry. Packing included: 1*Emergency Weather Radio with,1*Handy Braid belt,1*Carabiner,1*Compass,1*Micro Type-C Cable, and 1*User Manual.
